gen4maxima536 Posted November 19, 2007 Report Share Posted November 19, 2007 i remember someone posting this info before but can't find it. how do you tell the difference between the dogleg meant for the L and the one for the napZ? Quote Link to comment
datsunaholic Posted November 19, 2007 Report Share Posted November 19, 2007 The info posted was for the longtail, not the dogleg. I'm not sure anyone here has ever SEEN a NAPS-Z dogleg... they're extremely rare as they only came in '80-81 510s as an option. The only way to tell is by orientation... if the 2 top bell bolts are level with each other with the transmission sitting straight it's probably a NAPS-Z, since the L-series block has a built-in lean. Of course, if someone has a NAPS-Z dogleg I would trade an L-series dogleg for it. Quote Link to comment
gen4maxima536 Posted November 19, 2007 Author Report Share Posted November 19, 2007 well i guess i was just reading stuff wrong. the trasnmission i have, when the top to bolts are level, the shifter is leaning away from the driver so to say. i was probably just confusing my self looking at it again today Quote Link to comment
nismopu Posted November 19, 2007 Report Share Posted November 19, 2007 doesnt dislexic have a napz dog leg? Quote Link to comment
gen4maxima536 Posted March 9, 2008 Author Report Share Posted March 9, 2008 alright so i finally took a couple (bad) pictures tonight. i'm still not sure which one this is, but i'm leaning towards naps... Quote Link to comment
datzenmike Posted March 9, 2008 Report Share Posted March 9, 2008 Yes, it appears to me to be for a Z motor. Not an L for sure. If you look down the top centerline there's a casting 'seam' that continues up to the bolt pattern on the 'bell'. If the seam is closer to the right top bolt hole .... it's a NAPS Z . If the seam is to the left top bolt hole it's an L. Just remember...LEFT IS L, LEFT IS L More side pictures please. Quote Link to comment
gen4maxima536 Posted March 10, 2008 Author Report Share Posted March 10, 2008 alright. i'll take some more this weekend, or maybe dallas will go take a couple Quote Link to comment
510six Posted March 10, 2008 Report Share Posted March 10, 2008 They did make a 63 cm or short 5 speed for the napz powered 4x4 720 trucks, these are just basically a L motor 71cm tranny with a shorter 1st gear and a napz bellhousing. I used one of these trannys in my 510 and it held up quite well to 256 rwh and a bunch of drag lauches on slicks, I would suggest using this tranny(if you can find one) before the early 63cm dogleg tranny as I have had dogleg trannys lock in 3rd, 1st and 5th they are real POS`s. Quote Link to comment
gen4maxima536 Posted March 10, 2008 Author Report Share Posted March 10, 2008 right now i'm looking for an L dogleg or a shortened drive shaft. i need to check with the local machine shop to see how much it would be to shorten mine. Quote Link to comment
datzenmike Posted March 11, 2008 Report Share Posted March 11, 2008 They did make a 63 cm or short 5 speed for the napz powered 4x4 720 trucks, these are just basically a L motor 71cm tranny with a shorter 1st gear and a napz bellhousing. I used one of these trannys in my 510 and it held up quite well to 256 rwh and a bunch of drag lauches on slicks, I would suggest using this tranny(if you can find one) before the early 63cm dogleg tranny as I have had dogleg trannys lock in 3rd, 1st and 5th they are real POS`s. Not sure I've ever heard of a 63cm and a 71cm 5 spd before. The FS5W71B used with the NAPS (and many others) is not 71 cm long. The 71 refers to the distance between the internal main shaft and the counter shaft in mm, that's 7.1 cm. The FS5W71B is a little over 31.5" long, or about 80cm. The short tail stock FS5W71B is about 26+" long or 67cm. The NAPS 4X4 5spds were identical to the earlier L 5 spds for 1st gearing (3.592) the 'shorter 1st gear' (3.321) was used only on the 2wd trucks. I've seen quite a few NAPS 5 spds but only one shorty. Quote Link to comment
bonvo Posted March 20, 2008 Report Share Posted March 20, 2008 i have an l series dogleg im going to see if i can find a different tranny if i can i might be able to sell this one Quote Link to comment
gen4maxima536 Posted April 10, 2008 Author Report Share Posted April 10, 2008 i promised more pictures, so here they are. Quote Link to comment
datsunaholic Posted April 27, 2008 Report Share Posted April 27, 2008 That does look like a NAPS-Z dogleg. Trade you for a L-series one! Quote Link to comment
