jrock4224 Posted May 18, 2012 Report Share Posted May 18, 2012 Just by one week! I had to go to AZ for 5 days so I had to get my hours in before and worked three 12 hour shifts. Sucked missing out on a whole week. Plan is to have the wheels done and tires on by next week. Then front coilovers/camber plates and rear springs. Then swap the head with an a87 with good valve seats. Then after canby SU carbs and maybe header and exhaust. But who knows. jrock- snowflakes? These are six spokes. Snowflakes don't look good on 510s IMO, not enough lip. i know i seen some on a ratty wagon and thought they looked decent... i hated the wheels on coupes and 4 drs...for some reason on a lo wagon they looked pretty snazzy... i like your new wheels way better than the dp's or what ever are on there now Quote Link to comment
The Dat-side Posted May 19, 2012 Author Report Share Posted May 19, 2012 The ones I have now are Enkei Rally/Tarmacs, I'd like them if they were 15". They look really good spinning, but I haven't gotten a rolling shot of my 510. They're high offset too :( the ZX wheels will fit better and I'll be able to go lower. Quote Link to comment
Laecaon Posted May 19, 2012 Report Share Posted May 19, 2012 Well if you want any help I can definitely lend a hand! Quote Link to comment
The Dat-side Posted July 4, 2012 Author Report Share Posted July 4, 2012 Finally got it done. Front coilovers and camber plates. Rear Nissan competition springs. And some proper offset wheels. Rides pretty good. Quote Link to comment
DISLEXICDIME Posted July 4, 2012 Report Share Posted July 4, 2012 now lets put the white wheels on my car Quote Link to comment
The Dat-side Posted July 4, 2012 Author Report Share Posted July 4, 2012 I'm selling them to my cousin for his Z. They're too small for you. They're only 7". I took some pics. Shortened ZX struts for MR2 inserts and stock ZX struts. And stock 510 springs and Nissan Competition lowering springs. Quote Link to comment
MicroMachinery Posted July 4, 2012 Report Share Posted July 4, 2012 That looks good man.. good height and the offset complements it well. Quote Link to comment
Skib Posted July 4, 2012 Report Share Posted July 4, 2012 this needs to be on your hood Quote Link to comment
The Dat-side Posted July 4, 2012 Author Report Share Posted July 4, 2012 Abso-fucking-lutely! But not red, it'll look like a McDonalds delivery 510. Quote Link to comment
The Dat-side Posted February 24, 2013 Author Report Share Posted February 24, 2013 So yesterday morning my car had little torque when accelerating, and sounded extra loud. Almost like from the carb but haven't checked yet. Barely could make it up a steep hill. The idle was rough and would almost die at stops or even would if I let it. I'm thinking bigger hole in my exhaust and hence why I didn't bother making a new thread. But input would be nice. Quote Link to comment
The Dat-side Posted February 24, 2013 Author Report Share Posted February 24, 2013 Each plug is firing, but didn't remove plugs yet to check. I'll be doing that my next day off. Haven't checked compression yet. But idle got worse when I pulled the wire off each cyl. My only ideas would be exhaust or blown head gasket. The weird thing is this started first thing in the morning, not the night before. Quote Link to comment
The Dat-side Posted March 4, 2013 Author Report Share Posted March 4, 2013 My compression is: #1 60 #2 100 #3 90 #4 185. Ill be pulling the head tomorrow. Or at least trying to get up the nerve to do it. Pretty excited, but don't want to screw anything up more than it is. I need to make a timing chain wedge and that's about it. Then ill see what sort of condition the valves are in. Quote Link to comment
yello620 Posted March 5, 2013 Report Share Posted March 5, 2013 Did you have the throttle opened wide when thos numbers were taken? and was the motor warm? Quote Link to comment
The Dat-side Posted March 5, 2013 Author Report Share Posted March 5, 2013 Engine was cold but throttle was open. Quote Link to comment
The Dat-side Posted March 7, 2013 Author Report Share Posted March 7, 2013 First head removal success.... Fawk! Quote Link to comment
Laecaon Posted March 7, 2013 Report Share Posted March 7, 2013 It happens. I have been successful twice now with a drill and tap... Quote Link to comment
The Dat-side Posted March 7, 2013 Author Report Share Posted March 7, 2013 It happens. I have been successful twice now with a drill and tap... Then you are the man i need! (Nohomo) Copious amounts of homebrew await you! Quote Link to comment
The Dat-side Posted March 8, 2013 Author Report Share Posted March 8, 2013 Any tips for removing the rest? Hoping to avoid this. Just small movements at a time on each bolt? Quote Link to comment
nismo dr Posted March 8, 2013 Report Share Posted March 8, 2013 pb blaster. wait, pb blaster wait, small movements back then forward a little then back then froward then back then forward........is anyone else getting turned on? :wub: Quote Link to comment
Laecaon Posted March 8, 2013 Report Share Posted March 8, 2013 It does indeed suck. Which size headbolt? I have a lot of extra long ones, just no short ones... Quote Link to comment
The Dat-side Posted March 8, 2013 Author Report Share Posted March 8, 2013 It was on the #4 cam tower :) Quote Link to comment
yello620 Posted March 8, 2013 Report Share Posted March 8, 2013 Pretty sure I have a spare short one if you need one. Quote Link to comment
The Dat-side Posted March 9, 2013 Author Report Share Posted March 9, 2013 Got it off! Not thrilled with what I've found. Cyl #1 Between Cyl 2&3 Quote Link to comment
Shawk910 Posted March 9, 2013 Report Share Posted March 9, 2013 Yes that is a very bad find, I dont think anyone would be happy after seeing that Quote Link to comment
