SubwayGUY4 Posted February 16, 2010 Report Share Posted February 16, 2010 I looked and couldn't really find any good visual pictures of 15x8 in a 15 offset so..........with Stock 510 front suspension Will I rub the shock with a 15x8 +15? I know the +0 works but with this being in a little farther will I be ok? I'm more worried about the actual rim rubbing rather than the tires atm. Thanks any pictures would be great. and for reference these are the sportmax/xxr 501's Quote Link to comment
sssr20det510 Posted February 16, 2010 Report Share Posted February 16, 2010 I think you need 280zx front struts Quote Link to comment
SubwayGUY4 Posted February 16, 2010 Author Report Share Posted February 16, 2010 I forget whats the difference? When I asked my friend he said it doesn't mess with the geometry? Quote Link to comment
Skib Posted February 16, 2010 Report Share Posted February 16, 2010 I forget whats the difference? When I asked my friend he said it doesn't mess with the geometry? pulls the wheels in Quote Link to comment
MicroMachinery Posted February 16, 2010 Report Share Posted February 16, 2010 Generally, I see more people with FWD cars wanting positive offsets. I rarely see anybody with RWD wanting positive.. atleast in that width. In FWD alot of times, the front spindles stick out further than the rear ones on RWD, so that's why they want the positive offset. Alot of VW guys run those, so if you're wanting your tires to be flush, or "poke", you're gonna want either a "0" offset, or negative. But if you want your tires "tucked"(or further in), you'll want the positive offset, in which instance, you'll have to deal with clearance issues of your struts and fender wells. I personally would rather have my wheels as close to flush with the outside body lines of the car(if not out a little bit).. but that's just the stance I prefer. I'm running 14x7.5 up front with 280zx struts, and 14x8s in the rear(both "0" offset). I doubt that if the fronts were 14x8s with +15mm offset, that they'd clear.. I could be wrong, though.. Quote Link to comment
INDY510 Posted February 16, 2010 Report Share Posted February 16, 2010 pulls the wheels in Correct me if I'm wrong,,,, but I thought 280zx struts made a wider stance for a 510..... I always heard I could tuck lower offset wheels with stock struts...... That's why I shortened my stock 510 struts My 16x8 +0 wheels hardly rub on the coilovers on stock 510 struts.... I hear 280zx struts allow for a higher backspace I think a 15x8 +15 will NOT clear stock 510 struts with coilovers..... Maybe with 280zx struts, but you will NEED fender flares...... Because I think 280zx struts make a wider stance in the front.... You are better off finding some 15x7 +15 or even 15x6.5 would fit better with stock fenders Quote Link to comment
MicroMachinery Posted February 16, 2010 Report Share Posted February 16, 2010 Correct me if I'm wrong,,,, but I thought 280zx struts made a wider stance for a 510..... I think it actually narrows the front about 3/4" or something like that. I'd be stoked if they did widen it.. every little bit helps :cool: Quote Link to comment
SubwayGUY4 Posted February 16, 2010 Author Report Share Posted February 16, 2010 yeah I thought the 280zx actually widened. Thats cool to know they actually narrow it. I'll probably be cutting it close with the +15....... My goal was to not stick outta the fenders but, If in all case I can just slap on some spacers to clear if I had to.....I might as well have gotten the zeros.... Oh well we'll see thanks for all the input Quote Link to comment
paradoxx Posted February 16, 2010 Report Share Posted February 16, 2010 I think they will bump the strut, I have 15X8 0 offset and have a clearance of 2cm between the wheel and the strut, stock 510 struts. Quote Link to comment
SubwayGUY4 Posted February 17, 2010 Author Report Share Posted February 17, 2010 if you have 2cm of space.... wouldn't that mean that I'd have 5mm of clearance? lol Quote Link to comment
SubwayGUY4 Posted February 24, 2010 Author Report Share Posted February 24, 2010 Well for future reference I suppose..........just like it says 5mm of clearance........... oh and don't mind the paint. :rolleyes: 15x8 15 offset 195/50 front 205/50 rear Front Rear Quote Link to comment
MicroMachinery Posted February 24, 2010 Report Share Posted February 24, 2010 Nice, I like that. Zoom out; let's see the BIG picture ;) Quote Link to comment
paradoxx Posted February 24, 2010 Report Share Posted February 24, 2010 you will rub the rear tires..... Quote Link to comment
SubwayGUY4 Posted February 24, 2010 Author Report Share Posted February 24, 2010 Yeah the rear would rub the fender but it was already slightly rolled. It doesn't rub and I'll try to get a picture when its not raining Quote Link to comment
bonvo Posted February 24, 2010 Report Share Posted February 24, 2010 use the rain to wet sand it lol i remember you saying it needed it at the last suisun meet i was at Quote Link to comment
toylet Posted March 5, 2010 Report Share Posted March 5, 2010 Correct me if I'm wrong,,,, but I thought 280zx struts made a wider stance for a 510..... I always heard I could tuck lower offset wheels with stock struts...... That's why I shortened my stock 510 struts My 16x8 +0 wheels hardly rub on the coilovers on stock 510 struts.... I hear 280zx struts allow for a higher backspace I think a 15x8 +15 will NOT clear stock 510 struts with coilovers..... Maybe with 280zx struts, but you will NEED fender flares...... Because I think 280zx struts make a wider stance in the front.... You are better off finding some 15x7 +15 or even 15x6.5 would fit better with stock fenders I think it actually narrows the front about 3/4" or something like that. I'd be stoked if they did widen it.. every little bit helps yeah I thought the 280zx actually widened. Thats cool to know they actually narrow it. I'll probably be cutting it close with the +15....... My goal was to not stick outta the fenders but, If in all case I can just slap on some spacers to clear if I had to.....I might as well have gotten the zeros.... Oh well we'll see thanks for all the input I think they will bump the strut, I have 15X8 0 offset and have a clearance of 2cm between the wheel and the strut, stock 510 struts. everyone in this forum "thinks". Quote Link to comment
Guest kamakazi620 Posted March 6, 2010 Report Share Posted March 6, 2010 There for they "am" Quote Link to comment
JDM510 Posted March 6, 2010 Report Share Posted March 6, 2010 soo much mis information in this thread its a total FAIL!!!! lol like 2 angry monkeys trying to fuck a football Quote Link to comment
MicroMachinery Posted March 7, 2010 Report Share Posted March 7, 2010 Oh sweet, an expert is here to help out. Go ahead and steer our friend in the correct direction, will you? :rolleyes: Quote Link to comment
JDM510 Posted March 7, 2010 Report Share Posted March 7, 2010 nah ill let you steer them you are about the only one that had a response that was valid Quote Link to comment
SubwayGUY4 Posted March 8, 2010 Author Report Share Posted March 8, 2010 Its alllll good shit fits. :) Quote Link to comment
MicroMachinery Posted March 8, 2010 Report Share Posted March 8, 2010 Sweet dude, glad to hear. I'll be even MORE glad to see... so... PICS! :) Quote Link to comment
SubwayGUY4 Posted March 10, 2010 Author Report Share Posted March 10, 2010 I would but cars undergoing a ka now. till then! Quote Link to comment
