WTB-What The HeLL iS ThaT PieCE CallEd? 620
  • Replies 13
The "Set" is all the pieces. That one piece is generally called by Nissan the upper grille surround.
But since Mike is usually right, I checked the 620 parts catalogs:
* USA catalog names it "Hood Front Moulding". The catalog also has a TYPO where it says "Set" next to the part number
* JDM catalog names it "MOULDING-UPPER SURROUND" (1976-1978 620 catalog) or "MOULDING-hood, front" (1972-1975 catalog, PN 62310-B5000)
Not trying to be a dick... But last time I checked at the dealer they did not supply them anymore. It took maybe 6 620 to find an ok one. Had 3 of them but rusted, Was gonna make one good one out of the three I had. Threw them away since I didn't need them anymore.
I got it off this one.
As long as its not rusted, kinked, you can fix it. If its rusted leave it. Kinked..... You can probably bend it back but its very frail and my snap. If you break the bolts you can replace them with some ford falcon trim bolts.
http://www.mrgusa.com/pdfs/40-43mclips.pdf
yep...
