bigjoe619 Posted December 22, 2009 Report Share Posted December 22, 2009 :mad:I was driving my 510 yesterday and i guess the oil pump failed and my motor seized i dont know if im gonna build the same l 20 motor with the 89mm flat top pistons or try something new. it suks cause i didnt have more then 300 miles on the motor... o well:mad: Quote Link to comment
MicroMachinery Posted December 22, 2009 Report Share Posted December 22, 2009 (edited) Damn dude, that sucks.. didn't have the oil pressure switch hooked up? Edited December 22, 2009 by MicroMachinery Quote Link to comment
datzenmike Posted December 22, 2009 Report Share Posted December 22, 2009 (edited) 86 mm flattops. I doubt the L20b will take a 4mm overbore. How the hell does an oil pump fail? Sure it's seized? Why didn't you stop when the little red light came on? The Nissan oil pressure switch is set for 5-8 lbs. Maybe no oil? Edited December 22, 2009 by datzenmike Quote Link to comment
HRH Posted December 22, 2009 Report Share Posted December 22, 2009 Any more info on what seized? Abrupt stop, slow declining, with a gut wrenching noise? Oil pump failure is rare. I know silicone bits can kill one, like if you silicone the oil pump gasket (don't). But even with severely low oil pressue, an L can last forever. However, overheating or improper bore to piston clearance can certainly lead to failure. Quote Link to comment
bigjoe619 Posted December 22, 2009 Author Report Share Posted December 22, 2009 the pistons are chevy vega flat tops and the car had and still has oil there was a tapping sound as i got off the free way then it just shut off.. the starter wont turn it and i had a partner pull me home. while he was pulling me i put the tranny in second and let the clutch out and the back wheels locked up and the motor still wont turn.. i will pull it out and see what is messed up it s probably bored too much the temp guage said it was running around 200 degrees the wire was off the oil sending unit i didnt know Quote Link to comment
MicroMachinery Posted December 22, 2009 Report Share Posted December 22, 2009 I would check the cam towers first. I bought my 510 w/ a seized motor, which was run out of oil, and all it turned out to be was that the cam seized. The bottom end would still turn over. Quote Link to comment
bigjoe619 Posted December 22, 2009 Author Report Share Posted December 22, 2009 the cam and top end are good, i just pulled the valve cover , put a 3/4 socket on the bolt that holds the cam sprocket and it moved a little with the tension of the timing chain, so i pulled the sprocket off and moved the cam back and fourth but not rotating past the lobes of the cam that it was already sitting at. so hopefully it is just a bearing i will find out in the next couple days Quote Link to comment
hessianben Posted December 22, 2009 Report Share Posted December 22, 2009 this is a long shot, but.... check the starter. I thought I had a dead battery, so I tried to push start it, and it just skidded and bucked! turns out that the starter bolts came loose and the starter gear was wedged against the flywheel, not allowing it to turn. Check that for shiggles. Quote Link to comment
bigjoe619 Posted December 22, 2009 Author Report Share Posted December 22, 2009 i couldnt be that lucky lol.. i will have to do a block i will hopefully have it back on the road in a few weeks i cant really spend the money rite now i would go with a KA motor but those 44mm carbs sound so damn good... Quote Link to comment
Pacific coast Datsun Posted December 22, 2009 Report Share Posted December 22, 2009 Damm Joe thats gottta suck. Sounds like something on the bottom end came loose. Get Brian over there..you guys can get it fixed im sure. Lemme know if you need a hand. Quote Link to comment
bigjoe619 Posted December 22, 2009 Author Report Share Posted December 22, 2009 thanks Mark.. the motor almost ready to come out i have already started messing with it... Quote Link to comment
banzai510(hainz) Posted December 22, 2009 Report Share Posted December 22, 2009 I cant believe oil pump failure!!!!!! as for the 4mm overbore. where you guys get the headgasket? let me know Quote Link to comment
datzenmike Posted December 22, 2009 Report Share Posted December 22, 2009 ....the wire was off the oil sending unit i didnt know When you turn the ignition on the red oil pressure warning light in the dash lights up to show the bulb/system is working. Too bad you missed that, maybe could have saved the motor. Quote Link to comment
bigjoe619 Posted December 22, 2009 Author Report Share Posted December 22, 2009 you have to use a nap z head gasket and cut the front of the gasket off where it goes on the timing chain cover and use a l series the front of a l series gasket... the compression is high but runs very well.. a pair of 44mm mikunis and a A87 head with a big cam the power is really good for a l series... i take all the blame i should have hooked up my guages instead of tryen to drive it.. o well a few more weeks and it will be back alive Quote Link to comment
bigjoe619 Posted January 6, 2010 Author Report Share Posted January 6, 2010 Today i pulled my motor and put it on the stand, took the oil pan off and checked the rod berrings #4 rod berring spun. Quote Link to comment
MicroMachinery Posted January 6, 2010 Report Share Posted January 6, 2010 Ouch. Now you have to figure out what caused this mess. Quote Link to comment
