sssr20det510 Posted December 15, 2009 Report Share Posted December 15, 2009 Looking for Z22 short block cheap and local Link to comment
DISLEXICDIME Posted December 15, 2009 Report Share Posted December 15, 2009 just buy my l20 Link to comment
sssr20det510 Posted December 15, 2009 Author Report Share Posted December 15, 2009 not cheap enough LOL and i want turbo Link to comment
DISLEXICDIME Posted December 15, 2009 Report Share Posted December 15, 2009 not cheap enough LOL and i want turbo put the turbo on my block Link to comment
sssr20det510 Posted December 15, 2009 Author Report Share Posted December 15, 2009 i thought that motor is high compression Link to comment
DISLEXICDIME Posted December 15, 2009 Report Share Posted December 15, 2009 no that's the l18 in my car Link to comment
sssr20det510 Posted December 15, 2009 Author Report Share Posted December 15, 2009 whats the cr Link to comment
DISLEXICDIME Posted December 15, 2009 Report Share Posted December 15, 2009 dont know its a stock rebuild .02 over (12cc dish pistons) with a a87 penut go to ozdat and figure it out Link to comment
sssr20det510 Posted December 15, 2009 Author Report Share Posted December 15, 2009 I couldn't get it to give me cr Link to comment
datzenmike Posted December 15, 2009 Report Share Posted December 15, 2009 8.89 if head not shaved. Link to comment
elmerfudpucker Posted December 15, 2009 Report Share Posted December 15, 2009 8.89 if head not shaved. Dollar says he knew that off the top of his head!:D Link to comment
sssr20det510 Posted December 15, 2009 Author Report Share Posted December 15, 2009 Dollar says he knew that off the top of his head!:D I was going to ask were is mike when you need him LOL Link to comment
datzenmike Posted December 15, 2009 Report Share Posted December 15, 2009 I'm snowed in. My work partner phoned to say to not bother coming in today. I don't care for the on line calculators. I tried one and it was a pain to use gave an answer that was out there. Lots of useless blank spaces.... maybe me, but I won't trust it. I work it out with a hand held HP 48 G (overkill) but plugging in your own numbers makes you think more about what you're doing and errors are right there for you to see. It's easy to overlook something the other way. I have a page (not finished yet) for the L20B motor with everything listed for the stock bore (85mm) volume 487.75cc, the deck volume in plus or minus volume 2.55cc, crushed gasket volume 6.8cc, piston dish 11.36cc and a choice of open or closed head volume and a calculated compression for either. I also have it for an 86mm and an 87mm oversize piston. For example if 280z flattops are substituted I just go down to the 86mm bore and add all the numbers and leave the dish volume out... bam! 10.11 with stock open head. Takes 10 seconds for easy ones. I really should sit down and work out the rest for the oversize L16/18 and the Z20/22/24 engines. It doesn't give every possible combo but it does speed up the answer by adding or subtracting known volumes. Link to comment
hang_510 Posted December 15, 2009 Report Share Posted December 15, 2009 I tried one and it was a pain to use gave an answer that was out there. Lots of useless blank spaces.... maybe me, but I won't trust it. I work it out with a ... ... slide rule and abacus. Link to comment
sssr20det510 Posted December 15, 2009 Author Report Share Posted December 15, 2009 this is what dislexicdime was saying http://www.ozdat.com/ozdatonline/enginedesign/ Link to comment
tdaaj Posted December 16, 2009 Report Share Posted December 16, 2009 i've got a z22 bottom end. no timing cover but has new bearings and piston rings, $250? Link to comment
sssr20det510 Posted December 16, 2009 Author Report Share Posted December 16, 2009 a little more than im looking to spend Link to comment
Sealik Posted December 24, 2009 Report Share Posted December 24, 2009 I have 3 complete Z22s....(truck)......but....I'm in B.C.....north of Kamloops Link to comment
