kiznook Posted December 3, 2009 Report Share Posted December 3, 2009 Cleaning up my wiring, curious what this is for before I remove it Quote Link to comment
motavated Posted December 3, 2009 Report Share Posted December 3, 2009 Headlight? Quote Link to comment
banzai510(hainz) Posted December 3, 2009 Report Share Posted December 3, 2009 Believe that is the 3rd gear swicth with the dual points set up. usually mounted near the radiator. work in conjusction with the one on the fire wall in the plastic case with the throttle linkage I polish it up then take to nearest garbage can and throw IN!!!!!!!!! Quote Link to comment
kiznook Posted December 3, 2009 Author Report Share Posted December 3, 2009 That's what I was thinking, but I forgot about points so I was a little confused as to why it needed to exist in the first place. Quote Link to comment
kiznook Posted December 3, 2009 Author Report Share Posted December 3, 2009 (edited) What about this bad boy. Not the voltage regulator but the relay with the 4 wire connector. 2 of the wires splice into the alternator wiring, I didn't trace the other 2 yet. What does it do?? Edited December 3, 2009 by kiznook Quote Link to comment
slodat Posted December 3, 2009 Report Share Posted December 3, 2009 In a '72 I ***think*** that is part of the reverse light circuit. I'm operating off memory here.. Quote Link to comment
Duke Posted December 4, 2009 Report Share Posted December 4, 2009 It could also be the automatic choke relay. Quote Link to comment
kiznook Posted December 4, 2009 Author Report Share Posted December 4, 2009 white/blue splices to "IG" on voltage regulator yellow splices to "N" on voltage regulator black splices to ground blue runs over near wiper motor and has a bullet connector followed by a short pigtail with a rubber covered eyelet ATTATCHED TO NOTHING must be choke/carb related!? Quote Link to comment
Papi Chulo Posted December 4, 2009 Report Share Posted December 4, 2009 that is the electric choke relay Quote Link to comment
banzai510(hainz) Posted December 4, 2009 Report Share Posted December 4, 2009 your 72(start of the autochokes in datsuns) will be the choke relay as noted from the other posts Quote Link to comment
Braden Posted December 4, 2009 Report Share Posted December 4, 2009 your 72(start of the autochokes in datsuns) will be the choke relay as noted from the other posts anyone had a problem with them going bad causing the choke to fail? maybe i need one? Quote Link to comment
