izzo Posted November 13, 2009 Report Share Posted November 13, 2009 anyone got some? looking for 4.... lemmy know a ratsun price Link to comment
hang_510 Posted November 13, 2009 Report Share Posted November 13, 2009 new cast piston should fit a ratsun budget. Link to comment
izzo Posted November 13, 2009 Author Report Share Posted November 13, 2009 (edited) **edit Looking for these for a friend. I don't know what brand/where to get them. Any help would be awesome :D I did some searching on google but didnt really see anything. Edited November 13, 2009 by h2theizzo Link to comment
datzenmike Posted November 13, 2009 Report Share Posted November 13, 2009 There were two made in 86mm size for the stock z and zx. One was almost 11cc dish and the other was a flattop. Both have the same pin height as the 4 cyl. L series motors. Link to comment
Skib Posted November 13, 2009 Report Share Posted November 13, 2009 I got a heads up , got my eye out ;) Link to comment
izzo Posted November 13, 2009 Author Report Share Posted November 13, 2009 Good lookin out, thanks skib. Thanks for that info Mike! :D Link to comment
DISLEXICDIME Posted November 14, 2009 Report Share Posted November 14, 2009 finde a z20 to steel them from Link to comment
datzenmike Posted November 14, 2009 Report Share Posted November 14, 2009 Z20s are the same bore (85mm) as the L20Bs, however the piston pin heights are different anyway. Link to comment
DISLEXICDIME Posted November 14, 2009 Report Share Posted November 14, 2009 oops my bad Link to comment
freaky510 Posted November 14, 2009 Report Share Posted November 14, 2009 sr has a 86mm but not sure about pin height.and I wonder if their would be a combo that would work Link to comment
freaky510 Posted November 17, 2009 Report Share Posted November 17, 2009 wow I never realized they where that hard to come bye :confused::confused::( Link to comment
izzo Posted November 17, 2009 Author Report Share Posted November 17, 2009 oh i know right no responses yet lol Link to comment
banzai510(hainz) Posted November 17, 2009 Report Share Posted November 17, 2009 I never really could find a set beside from nissan @ 50$ apc or from steward wilkison in austrailia has a listing. flattop is too high comp in a l20. Ok in L18. spend the money on cam and head porting closed champer head. go to junk yard and pull them out of a 280zx non turbo Link to comment
izzo Posted November 17, 2009 Author Report Share Posted November 17, 2009 I never really could find a set beside from nissan @ 50$ apc or from steward wilkison in austrailia has a listing. flattop is too high comp in a l20. Ok in L18. spend the money on cam and head porting closed champer head. go to junk yard and pull them out of a 280zx non turbo Thank you Hainz, can you verify what years they came in? Link to comment
freaky510 Posted November 17, 2009 Report Share Posted November 17, 2009 flattop is too high comp in a l20. Ok in L18. what??? to high for a L20 now iam really confused Thank you Hainz, can you verify what years they came in? L28 (late)------------ 38.1mm /0.0cc Flatop in '81-'83 ZX / 86mm bore Link to comment
banzai510(hainz) Posted November 17, 2009 Report Share Posted November 17, 2009 (edited) Freaky stock L20 pistons were 11.35 cc if remeber right. so by putting a Zero dish piston in there is going to put comp up to 11 to 1 or very close to it.11cc of volume removed is ALOT!!!!!!!! Most gas stations are 91octane around here. If running race or avgas then fine otherwise your looking for proplems and esp on a open chambered head as they detonate EZer than a closed chamber head.for a daily driven car is not practicle L20s has that extra stroke and notice its a taller block. All the Z car blocks have the same height L24-L28. so the variations on rod/crank lenght isnt all that much until the later l20 and Z series blocks came out. 81-83 non turbo are flattops 86mm is STD size on these motors 81-83 Turbo are 10.9cc this is all from memory unless soembody else has the info Edited November 17, 2009 by banzai510(hainz) Link to comment
Skib Posted November 17, 2009 Report Share Posted November 17, 2009 oh i know right no responses yet lol I use PM's ;) and as far as JY hunting goes, all 75-83 280Z/ZX will have 86mm pistons just double check the blocks are L28. Link to comment
izzo Posted November 17, 2009 Author Report Share Posted November 17, 2009 I use PM's ;) and as far as JY hunting goes, all 75-83 280Z/ZX will have 86mm pistons just double check the blocks are L28. word, thanks skibby!!! Link to comment
banzai510(hainz) Posted November 17, 2009 Report Share Posted November 17, 2009 I cant confirm that the 75-80 are flattops I know for sure that the 81-83 non turbo are flattops all else fail order these 86mm flattops 12010-P8612 enter in nissanparts.cc then begin your world of detonation pain Link to comment
Skib Posted November 17, 2009 Report Share Posted November 17, 2009 Im gonna be asking around with the Z guys and see what I can find Link to comment
freaky510 Posted November 20, 2009 Report Share Posted November 20, 2009 found a set going to pick them up this afternoon thanks for all your help:) Link to comment
freaky510 Posted November 26, 2009 Report Share Posted November 26, 2009 :(well the guy didnt have 86mm they where 85.5:mad: so I am on the hunt again i would like to find a set of 86mm pistons to stuff in my motor any leads would be great. Skib could you ask around again please :eek::( also i have read some where i could use sr20 pistons on z20 rods is this true?? any help would be great!!! Link to comment
freaky510 Posted November 27, 2009 Report Share Posted November 27, 2009 :(well the guy didnt have 86mm they where 85.5:mad: so I am on the hunt again i would like to find a set of 86mm pistons to stuff in my motor any leads would be great. Skib could you ask around again please :eek::( also i have read some where i could use sr20 pistons on z20 rods is this true?? any help would be great!!! any one have info ??? Link to comment
datzenmike Posted November 27, 2009 Report Share Posted November 27, 2009 Only that the Z20 had two different rod sizes 152.5mm and another with the dished piston that is almost 4mm shorter. If someone has the SR piston pin height I can work it out. Link to comment
