mklotz70 Posted November 10, 2009 Report Share Posted November 10, 2009 Again...mainly for the first timers. Over the years, I've found that if you can watch something being done, it raises the confidence level tremendously. I'm certainly no genius, so if I can figure this out, any one else can too!! The first vid is me correcting a previous move of the sprocket. Basically, same thing, but with slightly different info. 1 Quote Link to comment
Bleach Posted November 10, 2009 Report Share Posted November 10, 2009 nice. Is there a video with your last compression test results? Quote Link to comment
mklotz70 Posted November 11, 2009 Author Report Share Posted November 11, 2009 I did another thread for the compression test. The 4 deg change took the compression from 160-165 to 170-175 :) 1 Quote Link to comment
datzenmike Posted November 11, 2009 Report Share Posted November 11, 2009 Hey Mike, I liked the "I'm 100% retarded" part. :D Good stuff. Quote Link to comment
yello620 Posted November 11, 2009 Report Share Posted November 11, 2009 Mike, excellent video. You sure made that cam sprocket bolt look easy.:D Just so this is not overlooked, my 1976 620 factory service manual lists the torque spec for that cam bolt to be 87-116 ft.-lbs. Thats pretty darn tight.:) That spec is for the L20b, i dont have specs for the L16 or L18, but i bet that they are close to that. Quote Link to comment
mklotz70 Posted November 11, 2009 Author Report Share Posted November 11, 2009 Hey Mike, I liked the "I'm 100% retarded" part. :D Good stuff. It would be funnier if it weren't so true! :) Mike, excellent video. You sure made that cam sprocket bolt look easy.:D Just so this is not overlooked, my 1976 620 factory service manual lists the torque spec for that cam bolt to be 87-116 ft.-lbs. Thats pretty darn tight.:) That spec is for the L20b, i dont have specs for the L16 or L18, but i bet that they are close to that. Thanks! I put it on pretty tight, but with a 3/8" ratchet....I'm sure I wasn't anywhere near that. I'll pop the cover again and find a better way to hold the spocket. This is an L20b....and I agree..the other L's should be the same. 1 Quote Link to comment
fisch Posted November 11, 2009 Report Share Posted November 11, 2009 Heh... I think we need a sticky just for mike to take the lamen like me through the basics. "The skool bell w. Professor Klotz! Everything you newbs need to know!" Not that Mike has the time! Thanks for making these Mike! I am not relocking a cam, but know some day I will and will be right back into this thread. Quote Link to comment
mklotz70 Posted November 11, 2009 Author Report Share Posted November 11, 2009 We should get together and do a book along the lines of the Complete Idiots' guides. Pen/ink illustrations......... naw...way too much work!! :) It takes enough time just to upload the vids!! .....I just got a new flaring tool on monday.....I might get around to doing the how-to on tubing flaring today...we'll see :) 1 Quote Link to comment
DISLEXICDIME Posted November 12, 2009 Report Share Posted November 12, 2009 It would be funnier if it weren't so true! :) Thanks! I put it on pretty tight, but with a 3/8" ratchet....I'm sure I wasn't anywhere near that. I'll pop the cover again and find a better way to hold the spocket. This is an L20b....and I agree..the other L's should be the same. TORQUE IT OR IT WILL FALL OFF ! trust me :blink: Quote Link to comment
mklotz70 Posted November 12, 2009 Author Report Share Posted November 12, 2009 ....if I wasn't convinced before....I am now!! Thanks!! :) 1 Quote Link to comment
mklotz70 Posted September 15, 2012 Author Report Share Posted September 15, 2012 Re-generated the vids and posted to youtube. Quote Link to comment
