jesusno2 Posted October 18, 2009 Report Share Posted October 18, 2009 ok i searched every auto parts store in my vacinity today. trying to find the parts to replace my hard lines to the rear brakes on my goon. as far as i can tell the lines are 3/16 with a single flare with 10mm x 100 fittings. I have to replace the long section that runs the lenght of the car from the firewll to the rear axle ,and the soft line to the axle. then to the rear calipers (zx rear discs) where's a good place to find this hardline and fittings the rest i can have softlines or braided lines made. i would like to run softlines from the T on the axle to the calipers with banjo fittings. any recomendations for this stuff i searched online but im still seeing mostly standard double flare stuff. Quote Link to comment
ggzilla Posted October 18, 2009 Report Share Posted October 18, 2009 What you need is a generic brake line 'kit'. Double-flare is always used, regardless of the original type. Quote Link to comment
Just Joel Posted October 19, 2009 Report Share Posted October 19, 2009 You can get hard line through Napa... I used the dark gray line that can be "bent by hand" and it worked great on my Tacoma... I think I'll ultimately replace all the hard lines in my goon with this eventually. It has a nice finish and is easy to work with. Later Joel Quote Link to comment
yello620 Posted October 21, 2009 Report Share Posted October 21, 2009 (edited) ok i searched every auto parts store in my vacinity today. trying to find the parts to replace my hard lines to the rear brakes on my goon. as far as i can tell the lines are 3/16 with a single flare with 10mm x 100 fittings. I have to replace the long section that runs the lenght of the car from the firewll to the rear axle ,and the soft line to the axle. then to the rear calipers (zx rear discs) where's a good place to find this hardline and fittings the rest i can have softlines or braided lines made. i would like to run softlines from the T on the axle to the calipers with banjo fittings. any recomendations for this stuff i searched online but im still seeing mostly standard double flare stuff. You should be able to order the 3/16 line with correct metric fittings on the ends through Napa. But, as i have said before, Good luck finding a counterman that can find the correct part number to order.:fu: And you need to be using double flare lines too.:D The other way to do it is to buy the 3/16 line with ASE fittings on the ends and cut the end off and install metric fittings and then reflair. Don't bother going and buying one of those cheap $20 flare kits, those will really piss you off. Edited October 21, 2009 by yello620 Quote Link to comment
zenndog Posted October 21, 2009 Report Share Posted October 21, 2009 (edited) When I was redoing the brake lines in my 320 every store near me had low stock of all brake lines. They seemed to have many of the short metric 3/16 and more of the long SAE. and British SAE. Of course it was an exercise in futility to ask if they had separate fittings so i bought the short metric lines to get the fittings and then the long of any other 3/16 line to get the line. Then I just cut and paste, so to speak. This was because I needed to get the truck on the road and didn't plan ahead. If I am taking my time and plan ahead I just order everything I want. Once you know that the store you are using can order the parts, even if one particular counter person can't figure out what to do, someone else there should be able to. I have even had stores that would just direct me back to the parts bins for brake fittings etc. Then I will usually give them a list of all the parts that are out of and politely ask something like " are you guys just not going to stock this stuff anymore or what" It is usually full up the next time I come in. I must admit that I didn't read the whole thread but if someone hasn't mentioned yet, buy the best double flaring kit you can afford. The cheap ones just don't work, the ones you can rent or borrow from the parts stores are usually FUBAR. I have a cheap one, I think, used only once, that you can have for postage but I won't be doing you a favor, better to save the postage. Edited October 21, 2009 by zenndog Quote Link to comment
72240z Posted October 21, 2009 Report Share Posted October 21, 2009 You know I got a "cheap" double flare tool kit from sears because my back was to the wall at the time and it worked just fine. Don't even think it was 20 bucks I think it was 16 and change lol. Maybe I was lucky Idk. Quote Link to comment
yello620 Posted October 21, 2009 Report Share Posted October 21, 2009 You know I got a "cheap" double flare tool kit from sears because my back was to the wall at the time and it worked just fine. Don't even think it was 20 bucks I think it was 16 and change lol. Maybe I was lucky Idk. Lucky, yes. Those cheap ones will usually give a few good flares before the tubing starts sliding down on the clamp. Once that happens, throw it away. You might save the little inserts for when you buy a good tool. Quote Link to comment
72240z Posted October 21, 2009 Report Share Posted October 21, 2009 (edited) Idk I'll keep an eye out on your word but I just got done doing like 5 on my z and replaced all the brake lines on my moms grand prix. Still seems to be working fine. I could see that being a prob though at some point or on I guess even cheaper ones like from autozone or something. Edited October 21, 2009 by 72240z Quote Link to comment
freaky510 Posted October 23, 2009 Report Share Posted October 23, 2009 this is crap dont waist your cash Quote Link to comment
72240z Posted October 23, 2009 Report Share Posted October 23, 2009 I don't understand how there is such a strong neg opinion on something that has never failed me lol. Don't doubt you guys, and I know full well the quality flare tools that exist. It's just that thing works every time I use it. I have gotten over 50 flares out of it, for 16ish dollars I would say it's more then paid itself off. Maybe the sears one isn't as garbage in the quality department..... Quote Link to comment
fastdadd Posted October 23, 2009 Report Share Posted October 23, 2009 i have one just like that and never had a problem with it just take your time and all is well......time i have money i dont Quote Link to comment
