freaky510 Posted August 21, 2009 Report Share Posted August 21, 2009 Iam running a dcoe 45 on aL20b With a BIG cam. It will idle and rev smooth, But as soon as i put underload it stummbles on its face. My question is what jets would you guy recomend for me to run. I had one guy tell me to get a 165 main 180 air does this sound right to you guys ?? Thanks Freaky Quote Link to comment
Cuts metal like mad Posted August 22, 2009 Report Share Posted August 22, 2009 is this problem anywhere in the rpm range? low rpms? high rpms? please be more specific. Quote Link to comment
DISLEXICDIME Posted August 22, 2009 Report Share Posted August 22, 2009 i think kiznook is running a 190 main Quote Link to comment
freaky510 Posted August 22, 2009 Author Report Share Posted August 22, 2009 It stumbles from the start low rpm even if i rev it up and drop the clutch it starts cut out. right now it has a 200 and 140 in it and from what i read thats not even close to right Quote Link to comment
Cuts metal like mad Posted August 22, 2009 Report Share Posted August 22, 2009 check your timing... also you may consider getting your distributor recurved. Quote Link to comment
freaky510 Posted August 22, 2009 Author Report Share Posted August 22, 2009 so with those jets i should be fine??? lol i have spun my dist 360 and same thing Moved the cam to 3 been thru the whole timming Quote Link to comment
izzo Posted August 22, 2009 Report Share Posted August 22, 2009 Give me your carb, ill give you my weber and intake... thatll solve that right quick :D Quote Link to comment
Cuts metal like mad Posted August 22, 2009 Report Share Posted August 22, 2009 get a timing light! :lol: for a car like your, and running a side draft its almost a necessity. Your jets may be a little on the bi side, but not so much that you couldn't tune it in... (my opinion) Quote Link to comment
freaky510 Posted August 22, 2009 Author Report Share Posted August 22, 2009 get a timing light! [/quote/] lol i threw that thing away years ago lol at an idle its about 12 deg below tdc Quote Link to comment
MAG58 Posted August 23, 2009 Report Share Posted August 23, 2009 What emulsion tubes are you running? In My Opinion, It's more important for under load drivability than the Mains and AC's. You're hardly on the mains below 3k anyway. And what Accel jet? Quote Link to comment
moparvwfreak Posted August 23, 2009 Report Share Posted August 23, 2009 when i first rebuilt my weber on the 73, it would do that. idle nice, rev it without a real load and it was fine. as soon as i put a load on it, she would sputter and die. found out my float level was off. not enough fuel to keep it going while i was driving. adjusted the float and all was good again. Quote Link to comment
freaky510 Posted August 23, 2009 Author Report Share Posted August 23, 2009 What emulsion tubes are you running? In My Opinion, It's more important for under load drivability than the Mains and AC's. You're hardly on the mains below 3k anyway. And what Accel jet? iam running the f2 tube it has a 200air and a 140 main as for the accel jet i dont know when i first rebuilt my weber on the 73, it would do that. idle nice, rev it without a real load and it was fine. as soon as i put a load on it, she would sputter and die. found out my float level was off. not enough fuel to keep it going while i was driving. adjusted the float and all was good again. i will lookin to that. thanks Quote Link to comment
freaky510 Posted August 25, 2009 Author Report Share Posted August 25, 2009 so pulled everything off i could set my timming at full adv and gained about 1000 rpm. it will rev smooth sounds good can launch at about 2500 then falls all over it self i am lost everything seams to be working right Help i got a few week untill race time and i would like to have this thing running good the new jets will be here tomarrow i hope thats the problem Quote Link to comment
freaky510 Posted September 7, 2009 Author Report Share Posted September 7, 2009 (edited) OKay I have replaced everything in the ignition. Running a msd box (got it for cheap) a msd SS coil and a Mallory dual point dist. It all has its own power supply. I can launch hard with 3 guys in the car and i get up in the rpms and it stumbles all over then kicks back in why why why it never ran like this before. what i got and did Got a Norris cam 300 Dur 511 lift ( it was phlebs and hang510 i think) closed chamber head completely gone Thru Eric's old dcoe 45 (Ran great on his car) Msd 6200 ( IT was cheap lol) ran the same in stock set up too Msd SS coil (not as cheap as the box lol) Mallory dual point Dist.( have had it for awhile) Msd Helli coil wires put new jet in weber 185/165 everything has new points cap rotor wires you name it i went Thru it lol Iam lost. I have tried 3 different dist and the same thing stock or with the box. Actually with the box i got a little better performance out of it. We (mech and i)have the cool guy timing light (you can set you retard and advance and hits on zero pretty cool light (http://buy1.snapon.com/products/diagnostics/time_mt2661ap.asp) any way HELP Edited September 7, 2009 by freaky510 Quote Link to comment
mnementh666 Posted September 7, 2009 Report Share Posted September 7, 2009 I'm not much up on DCOE's, but I'd check fuel pump output and pressure, and the float level. Sounds like you're starving under load. :confused: Quote Link to comment
DISLEXICDIME Posted September 7, 2009 Report Share Posted September 7, 2009 did you check the small fuel filter on the weber ? they tend to clog. Quote Link to comment
kiznook Posted September 7, 2009 Report Share Posted September 7, 2009 are you running any vacuum advance? I think we had talked about that before, but I can't remember. I don't remember what's in my carb at the moment, I'll have to pop the top off and see. Quote Link to comment
freaky510 Posted September 7, 2009 Author Report Share Posted September 7, 2009 I'm not much up on DCOE's, but I'd check fuel pump output and pressure, and the float level. Sounds like you're starving under load. :confused: Iam adding a electric pump now. will check pressure,and levels again. how much fuel pressure should it be?? did you check the small fuel filter on the weber ? they tend to clog. yes are you running any vacuum advance? I think we had talked about that before, but I can't remember. I don't remember what's in my carb at the moment, I'll have to pop the top off and see. no vac advance running a curved dist or a mallory anywhere dist (lol) or stock dist. i have tried all 3 :lol: cool let me know what size just your running thanks all Quote Link to comment
DISLEXICDIME Posted September 7, 2009 Report Share Posted September 7, 2009 did you use soft mounts for that weber? did you over tighten the soft mounts so they dont flex? is your engine and distributor grounded? Quote Link to comment
freaky510 Posted September 7, 2009 Author Report Share Posted September 7, 2009 did you use soft mounts for that weber? did you over tighten the soft mounts so they dont flex? is your engine and distributor grounded? no soft mounts and yes its grounded Iam going to check the grounds anyway i was thinking that earlier Quote Link to comment
DISLEXICDIME Posted September 7, 2009 Report Share Posted September 7, 2009 (edited) that's your problem weber side drafts need soft mounts or else you fuck up the needles and floats. the vibration throws them all out of wack. so is it just bolted to the manifold? Edited September 7, 2009 by DISLEXICDIME Quote Link to comment
freaky510 Posted September 7, 2009 Author Report Share Posted September 7, 2009 even with a single sidedraft?? Quote Link to comment
DISLEXICDIME Posted September 7, 2009 Report Share Posted September 7, 2009 vibration still effects a single carb :P kiznook over tightened his and his floats got stuck and almost caught his car on fire Quote Link to comment
freaky510 Posted September 7, 2009 Author Report Share Posted September 7, 2009 okay now iam going to have to be a total idiot but what are you refing to some thing like this http://www.mgcars.org.uk/pics/barrett65b2.jpg the little rubbers against the mounting bolts Quote Link to comment
DISLEXICDIME Posted September 7, 2009 Report Share Posted September 7, 2009 http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=weber+45+soft+mounts&_sacat=See-All-Categories Quote Link to comment
