freaky510 Posted September 8, 2009 Author Report Share Posted September 8, 2009 okay the carb has been rebuilt and i have all the rubber parts the problem is at a higher rpm i lose 2 cylinders #2 and#3??? Iam running a separate ing system and eeven with the stock set up the 2 drop out as soon as i put my foot in it now if i baby it i goes fine??? we should chandge the name of this thread to my pos Quote Link to comment
DISLEXICDIME Posted September 8, 2009 Report Share Posted September 8, 2009 what size are your chokes ? what is your fuel pressure ? what fuel pump are you running ? Quote Link to comment
freaky510 Posted September 8, 2009 Author Report Share Posted September 8, 2009 (edited) what size are your chokes ? 33 what is your fuel pressure ? i dont know he says its getting plenty of fuel, but iam going to get gage on it for myself what fuel pump are you running ? stock but depending on what my pressure is i have an electric one tomarrow iam going to try the old jets,if the problem prosits we will then put a 32/36 on it and see if its the carb or a electical problem Edited September 8, 2009 by freaky510 Quote Link to comment
DISLEXICDIME Posted September 8, 2009 Report Share Posted September 8, 2009 gime you email and i will send you this book i have for tuning that carb . Quote Link to comment
freaky510 Posted September 8, 2009 Author Report Share Posted September 8, 2009 cool thanks for all your help Quote Link to comment
67411sss Posted September 8, 2009 Report Share Posted September 8, 2009 I have some redline softmounts you can have for free if you want them. i would sort out your float level first, sounds like no fuel under load also use those spring washers when mounting(i learn't the hard way= broken ears are not much fun. Do you have a fuel pressure regulator, they don't like more than . I think 8-9 mm is the setting for the float level. Let me know about those softmounts. Rory Quote Link to comment
freaky510 Posted September 8, 2009 Author Report Share Posted September 8, 2009 hell yea if you could ship them over night or whatever give me the price and i will pay pal you or send you cash ill pm you my addy thanks Quote Link to comment
DISLEXICDIME Posted September 8, 2009 Report Share Posted September 8, 2009 you got mail Quote Link to comment
freaky510 Posted September 9, 2009 Author Report Share Posted September 9, 2009 you got mail lol thanks printing it out now. Quote Link to comment
kiznook Posted September 9, 2009 Report Share Posted September 9, 2009 My specs are as follows: Main - 190 Emulsion Tubes - F16 Air Corrector - 145 I forgot to write down the idle jet # but I want to say 50F8?? Doesn't really matter as it sounds like you've got that much sorted out. Quote Link to comment
kiznook Posted September 9, 2009 Report Share Posted September 9, 2009 You say you have 165 main and 180 air...??? Main jet sits on top Emulsion tube goes under Air corrector is in the very bottom I think you might have these numbers backward, in which case, based on my setup, your air correctors are too big. I want to say that 140/f14?/140 is recommended for L20 If my theory on your numbers is correct, you need to downsize your air correctors, and maybe increase your mains. I guess the real question is if you're experiencing a too-rich, or too-lean situation. Quote Link to comment
freaky510 Posted September 9, 2009 Author Report Share Posted September 9, 2009 (edited) so after reading the weber pages that DISLEXICDIME sent me we have come to the conclusion that this was tuned down to run on a l16:eek: accoroding to the book i need a bigger choke and diffrent jets. We got it close,close enough to race :). so iam on the hunt to find some new jets and chokes. now according to the book i should be running 180 air 195 main 40mm choke so where does a guy find these before friday:lol: but we got it close it quit spuddering we mixed up some new jets and old to get it put it pulls hard all the way to 7100:eek: my mech says it has more Edited September 9, 2009 by freaky510 Quote Link to comment
DISLEXICDIME Posted September 9, 2009 Report Share Posted September 9, 2009 try it with 0ut the chokes Quote Link to comment
freaky510 Posted September 10, 2009 Author Report Share Posted September 10, 2009 try it with 0ut the chokes okay why not lol will try it out tomarrow Quote Link to comment
kiznook Posted September 10, 2009 Report Share Posted September 10, 2009 Correction. I had my numbers backward. My setup is: 145 main 190 air correctors f16 emulsion tubes on lz20 with flat-tops and peanut head, stock manifold with 2.25 exhaust and long y pipe Quote Link to comment
