nickelNdime Posted August 1, 2009 Report Share Posted August 1, 2009 need an electric dizzy for my l20 thats in my 510.done with the single point that doesnt work right!!!!!!i am located in nc Link to comment
NICOYA Posted August 1, 2009 Report Share Posted August 1, 2009 what do you mean electric dizzy? need an electric dizzy for my l20 thats in my 510.done with the single point that doesnt work right!!!!!!i am located in nc Link to comment
Mesh-71 Posted August 1, 2009 Report Share Posted August 1, 2009 what do you mean electric dizzy? A matchbox dizzy maybe? Link to comment
NICOYA Posted August 1, 2009 Report Share Posted August 1, 2009 do you mean single point distributor? canyou send me a few picture of yours so i can compare and i send you picture i have few and all different send at maxima777@roadrunner.com thanks Eddie A matchbox dizzy maybe? Link to comment
yello620 Posted August 1, 2009 Report Share Posted August 1, 2009 I have a "Matchbox" style electronic distributor with pedastal for a L20. Tested in my truck. Also comes with a coil, but i could not test thatin my truck. Asking $60 OBO plus shipping Link to comment
nickelNdime Posted August 28, 2009 Author Report Share Posted August 28, 2009 sorry for not being clear but yes i am looking for a matchbox style distributor for my l20. i was close to buying an original style electronic distributor that came on the l20 but was told its alot more work to install that and that the matchbox style is easier install plus a more reliable choice.can anyone elaborate on that.i have a crappy single point that doesnt work that well.what car or truck did the matchbox style distributor come out of.i heard its not an original part to the l20? thanks for any help. Link to comment
hang_510 Posted August 28, 2009 Report Share Posted August 28, 2009 ... the matchbox style is easier install plus a more reliable choice.can anyone elaborate on that. all correct. id buy the one for $60 from yello620! Link to comment
Phlebmaster Posted August 28, 2009 Report Share Posted August 28, 2009 Welcome to Ratsun. I hope you find your part. Link to comment
datzenmike Posted August 28, 2009 Report Share Posted August 28, 2009 (edited) ... i was close to buying an original style electronic distributor that came on the l20 but was told its alot more work to install that and that the matchbox style is easier install plus a more reliable choice.can anyone elaborate on that.i have a crappy single point that doesnt work that well.what car or truck did the matchbox style distributor come out of.i heard its not an original part to the l20? thanks for any help. There are two styles of EI (electronic ignition) distributors, the remote igniter and the matchbox. The first was used on California vehicles starting around '76 and on all Datsuns in '78. It used a reluctor and stator coil to pick up a magnetic signal. The signal was sent to a box inside the cab of the vehicle to be amplified and the resultant signal sent back out to the coil to fire it. There were 5-6 wires going to a 5" X 4" X 1" box. This system was called the 'remote igniter' because of the electronics box mounted inside the car. In '79 the remote box was miniaturized down to a smaller 1 .5" square 'match box' size and mounted on the outside of the distributor. The internal stator and reluctor were also improved. Both work about the same and are very reliable. The matchbox are neater looking and easier to install without the remote box to worry about. If you have a remote igniter distributor (dizzy) you can wire a GM HEI module to it and mount it inside the engine compartment. Here is a remote igniter box and dizzy. http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/DatsunEI006Large.jpg[/img]"] http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/EIdizzyremoteigniter.jpg[/img]"] Here is the matchbox dizzy inside. http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/EIdizzymatchbox.jpg[/img]"] Outside. http://i138.photobucket.com/albums/q251/datzenmike/Nissan%20Electrical/DatsunEI005Large.jpg[/img]"] The matchbox requires only two wires. One for 12 volts and one to the coil to fire it. The matchbox must be securely grounded to work properly. The 4 cylinder L series matchbox dizzy was used on all '79 and '80 L20B motors. No matchbox or remote igniter was used on the L16/18 motors. '79 200sx, 620, A10 '80 720 Edited August 28, 2009 by datzenmike Link to comment
Rubberman Posted August 28, 2009 Report Share Posted August 28, 2009 nickel, I have two, if that doesn't work out with yello. Link to comment
