Duke Posted June 1, 2009 Report Share Posted June 1, 2009 I'm rebuilding the Naps-z 5 speed that I am running in my car. I had originally thought that the input shaft bearing was bad, but it ended up being the main shaft bearing. I am having trouble getting the main shaft out. Has anybody done this before? Anybody have any tips for removing it? Or should I just source another tranny and forget about it? Quote Link to comment
datzenmike Posted June 1, 2009 Report Share Posted June 1, 2009 Do you have the front a rear case halves off? The Main shaft bearing you are referring to is mounted in the adapter plate correct? Quote Link to comment
Duke Posted June 2, 2009 Author Report Share Posted June 2, 2009 Yes it is. I have the transmission totally apart. I was just able to get the main shaft out, and the bearing. The kicker is that none of the bearings in the transmission feel bad, but I know it can be a different case when a load is applied. I think I may have gotten in over my head with the tranny rebuild. I have this feeling in my stomach that I will get it all back together and back in and it will be just as bad as before, or worse. We'll see I guess. Quote Link to comment
datzenmike Posted June 2, 2009 Report Share Posted June 2, 2009 Take pictures! :lol: I'll add them to may stockpile of tranny photos and one day I'll use it on a post and you'll chime in with 'hey that's my tranny!!!' Quote Link to comment
Icehouse Posted June 2, 2009 Report Share Posted June 2, 2009 Duke was the tranny loud or just shifting bad? Reminds me of when I was a kid. I got a YZ80 for cheap because it had a bent rod. well it turns out when splitting the case some knowledge of gears is required.... needless to say that one never made it back together :D Quote Link to comment
Duke Posted June 3, 2009 Author Report Share Posted June 3, 2009 Mike, I am really bad at taking pictures in the middle of a project, but I will post some of what I did take. Duke was the tranny loud or just shifting bad? It shifted fine, but it would make noise under deceleration and above 3K RPM. I am pretty sure it was a bad bearing. I replaced all the bearings in the transmission, and I was able to get it back together. I still have to put the front and rear cases back on but I don't have any extra parts! I'm just hoping it works and doesn't make any bad noises once it is back in the car. Reminds me of when I was a kid. I got a YZ80 for cheap because it had a bent rod. well it turns out when splitting the case some knowledge of gears is required.... needless to say that one never made it back together :D I had a feeling that I would have the same thing happen to me. However, my dad convinced me to give it a go, and I am glad I did because I really learned a lot about the inner workings of a transmission, something that has been a kind of "magic box" to me for a while. Fingers crossed it all works as intended in the end! Quote Link to comment
slodat Posted June 3, 2009 Report Share Posted June 3, 2009 The dogleg 5 speed that was in my 510 earlier this year made the same kind of noise. I sold it to its present owner explaining the noise and recommended replacing bearings. He replaced the bearings and the transmission is quiet and in his truck. Fingers crossed for you Duke! Quote Link to comment
Icehouse Posted June 3, 2009 Report Share Posted June 3, 2009 I had a feeling that I would have the same thing happen to me. However, my dad convinced me to give it a go, and I am glad I did because I really learned a lot about the inner workings of a transmission, something that has been a kind of "magic box" to me for a while. Fingers crossed it all works as intended in the end! I've only got as far as taking the housing off exposing the magic... I would like to install new bearing and sink rows in a tranny just for fun. Just the though of getting it in and having to pull it back out reminds me to put it on the bottom of the list :D Good luck buddy! Quote Link to comment
moparvwfreak Posted June 25, 2009 Report Share Posted June 25, 2009 It shifted fine, but it would make noise under deceleration and above 3K RPM. my 78 does that. i have been thinking its a bearing. Quote Link to comment
