Guest DatsuNoob Posted August 6, 2007 Report Share Posted August 6, 2007 So there's been a weird click in my front end when I come to a stop. I figured it had something to do with the brakes since the old lady I bought it form said it had brake problems, and her husband(deceased) was pretty much the only guy who knew for certain what was up. So I changed the brakes, checked all suspension connections, even replaced the shocks, and still it clicks and there is a slight lift forward when I brake. Not sure what's going on here. As much as I hate to take my vehicles in for service(rare), I might take it in to Schwab to see if they can diagnose it, unless you guys got a suggestion for me I haven't tried yet. Thanks. Quote Link to comment
SHADY280 Posted August 6, 2007 Report Share Posted August 6, 2007 ummm there are lots of parts that can go click when braking motion is set forth. try the bolts on the caliper, if they are loose sometimes they click, unless you have the drums, then it could be the springs inside. it could also be a part of the suspension moving, like the t/c rod, try the bolts, see what loose first, then take it in. youll feel like less of a retard when you go in then, especially if they told you it was something stupid. Quote Link to comment
yello620 Posted August 6, 2007 Report Share Posted August 6, 2007 Les schwab does FREE brake checks. And FREE suspension checks. You just have to play dumb and act as if you want them to fix it, they will give you and estimate and want to fix it right then or set up an appointment. Later Jason Quote Link to comment
Icehouse Posted August 6, 2007 Report Share Posted August 6, 2007 I think that "click" came factory in all datto's :D My truck does the same thing, I can't tell if its coming from the rear or the front though. I just turn up my ipod :D Quote Link to comment
lynchfourtwenty Posted August 6, 2007 Report Share Posted August 6, 2007 I think that "click" came factory in all datto's :D My truck does the same thing, I can't tell if its coming from the rear or the front though. I just turn up my ipod :D HAHAH .. IPOD.. in a datsun?? thats unheard of Quote Link to comment
phatdave Posted August 6, 2007 Report Share Posted August 6, 2007 He said ipod he meant 8 TRACK!.."Rollin,Rollin, Rollin on the River...." Quote Link to comment
]2eDeYe Posted August 7, 2007 Report Share Posted August 7, 2007 Put your truck on jack stands. Pull the wheels. Get about a 2' pry bar. Try to use the frame for leverage whenever possible frame and pry every joint in the front end. You'll find everything that's loose, which is probably alot in a 30+ year old truck. If you don't know the source of any of the front end components (meaning, if you haven't replaced them personally) replacing them all would be a good idea. If you do it in stages it's fairly inexpensive. I put about $200 into all of the steering components on my truck, links and idler arm, and the difference was dramatic. Ball joints and bushings are next on my list. The pry bar will help you sort out your list ;) Quote Link to comment
Bleach Posted August 7, 2007 Report Share Posted August 7, 2007 Icehouse has an iPod and internet in his 1978 Datsun. :D he's all about swapping newer technology into older cars. Quote Link to comment
Guest DatsuNoob Posted August 10, 2007 Report Share Posted August 10, 2007 I got an ipod in mine too, people look at me almost in disbelief when I pull up to them at a light changing songs. It must look outta place in my rig. Quote Link to comment
Icehouse Posted August 11, 2007 Report Share Posted August 11, 2007 Icehouse has an iPod and internet in his 1978 Datsun. :D he's all about swapping newer technology into older cars. hehe I sure do :D I got an ipod in mine too, people look at me almost in disbelief when I pull up to them at a light changing songs. It must look outta place in my rig. Me to, and when my 620 waists there V6 kia haha Quote Link to comment
