Edz280zx Posted March 16, 2009 Report Share Posted March 16, 2009 Guess I'll be starting on this truck here pretty quick, so I'll start a thread on it. Here's some pics of it right now....pretty rough looking:lol: Went ahead and pulled it out of the dirt and threw some tires and wheels I had laying around on the back of it....looks kinds red neckish..:D Picked up a factory console, but I don't think I'm gonna use it..I'll probably throw it up for sale in a couple days..also grabbed the radio delete panel since the radio was in the console. The plan is to get this running and use it as a DD for my new job. Need a gas tank and a radiator, so I'll be searching for those parts as I redo the brake and clutch systems. This truck is going to be a true "rat" as I'm not planning on doing alot of bodywork, except for the rear cab mounts. To be continued..... Quote Link to comment
bonvo Posted March 16, 2009 Report Share Posted March 16, 2009 sweet man for a radiator look into one for a 720 bigger and it still fits Quote Link to comment
athoose Posted March 16, 2009 Report Share Posted March 16, 2009 That is rough!:eek: It's got AC though;) Quote Link to comment
Edz280zx Posted March 16, 2009 Author Report Share Posted March 16, 2009 sweet man for a radiator look into one for a 720 bigger and it still fits Cool! thanks for the info man That is rough!:eek: It's got AC though;) :D...Yeah, just a touch of rust!! Quote Link to comment
bonvo Posted March 16, 2009 Report Share Posted March 16, 2009 Cool! thanks for the info man yeah and its probibly more readily available its a 3 row and its wider then the stock 620 i had a 620 rad in my 610 it was to narrow for the 610 opening and when i test fited the 720 rad in the 610 the mounts were just shy of the headlight bucket mounts it will fit with much better cooling :D...Yeah, just a touch of rust!! thats not bad rust it looks to be about 99% surface though pics dont show all the little spots Quote Link to comment
Edz280zx Posted March 16, 2009 Author Report Share Posted March 16, 2009 Oh..it's got rust!! That, and I need to replace the rear cab mounts...I can literally lift the rear of the cab up...lol Quote Link to comment
bonvo Posted March 16, 2009 Report Share Posted March 16, 2009 holy rusted metal batman:eek::eek: i love the "custom" battery tray :lol: its all good got a welder? get to work bro weld that shit back together lol Quote Link to comment
Edz280zx Posted March 16, 2009 Author Report Share Posted March 16, 2009 lol...yeah, I have access to one. I'm thinking about calling this "project Rustun" LOL Quote Link to comment
bonvo Posted March 16, 2009 Report Share Posted March 16, 2009 idk about that one ive seen rust alot worse then that Quote Link to comment
Edz280zx Posted March 19, 2009 Author Report Share Posted March 19, 2009 Weeellll....last night I did a compression check just to make sure. It came out to 75. The engine hasn't been run in about 7 or 8 years and this was a dry compression check. I did notice that it was slowly rising the more I cranked..I stopped because I didn't want to drain the battery. What do you guys think?? Quote Link to comment
athoose Posted March 19, 2009 Report Share Posted March 19, 2009 Should be at least 128. That's turning it with a charged battery. Doesn't sound good. You can a small amount of oil to see if its piston or valve. Quote Link to comment
Edz280zx Posted March 19, 2009 Author Report Share Posted March 19, 2009 Yeah...I'm gonna try that tonight when I get off work. I'm also gonna put a coil on it and see if it will fire at all. Quote Link to comment
athoose Posted March 19, 2009 Report Share Posted March 19, 2009 Check all cylinders. Are all this low? Could be a blown head gasket. Quote Link to comment
420n620 Posted March 19, 2009 Report Share Posted March 19, 2009 pull your valve cover and make sure your getting oil to all the rockers. also pull all the sparks plugs so starter doesn't have to work as hard. your compression might rise after you get it running. When a engine has sit for a long period of time, rings seem to lose there seat but might reseat after its been ran for a period of time. good luck Quote Link to comment
Edz280zx Posted March 19, 2009 Author Report Share Posted March 19, 2009 Thanks guys...this gives me some stuff to do tonight. Quote Link to comment
Edz280zx Posted March 20, 2009 Author Report Share Posted March 20, 2009 Raise a flag over her and start playin' Taps....she's dead boys. Guess this one's going to that great scrap pile in the sky..... Quote Link to comment
420n620 Posted March 20, 2009 Report Share Posted March 20, 2009 don't send her off yet, what did you find out. :confused: I'm sitting down for the bad newz........................... :( Quote Link to comment
Edz280zx Posted March 20, 2009 Author Report Share Posted March 20, 2009 Engines toast...compression #'s were horrid...like none came up over 100 and one cylinder was at 35...oh well Quote Link to comment
Edz280zx Posted March 20, 2009 Author Report Share Posted March 20, 2009 The engine could probably be rebuilt...It's just not in the budget right now. Quote Link to comment
420n620 Posted March 20, 2009 Report Share Posted March 20, 2009 (edited) with the truck sitting for so long it does not surpise me that the compression is down, rings have probalay lost there seat. are you getting oil up to the rockers, if so, get it running and let it get up to temperature and let it run for awhile. when it does reach temp, rev it up to 3 or 4 thous then let off, keep doing this and maybe the rings will reseat them selfs again. When you've done this for about 15 to 20 minutes, take another compression test. Edit : make sure that all the valves are adjusted, plus make sure none of the valves are stuck open.. Edited March 21, 2009 by 420n620 added info Quote Link to comment
Edz280zx Posted March 20, 2009 Author Report Share Posted March 20, 2009 I'll check it out when I get time...the truck isn't going anywhere for awhile anyway. Thanks for the help man. Quote Link to comment
athoose Posted March 21, 2009 Report Share Posted March 21, 2009 Is that a frothy beer in a health stein? Sorry to hear about your low compression. Time to pour another health shot.:) Quote Link to comment
