Lozer Posted February 23, 2009 Report Share Posted February 23, 2009 Is this do able? im looking into the ka swap and wondering if i can use my current trans? What do i need to do it? Quote Link to comment
datzenmike Posted February 23, 2009 Report Share Posted February 23, 2009 Any L series tranny will physically bolt to the KA, however the KA, just like the Z series, sits more vertically than the L series when mounted. The L series is tilted about 12 degrees to the right and the tranny is oriented with the shifter vertically in the cab. If you bolt it to a KA it will be rotated 12 degrees to the left and the shifter will be against your right knee and the tranny will need a 12 degree wedge added to the mount. I suppose the shifter could be bent vertical. Don't see why it couldn't be done. If you have access to and old or damaged Z series 5spd, you could swap the front case with the engine bolt pattern onto your L series tranny. The Z and the KA have the same tilt so the Z front case would correct this on the L tranny. For the best solution use the KA tranny. It sits properly oriented in the car, is a far superior tranny and was built to handle the KA's power. The drive shaft will need shortening. I know you don't want to do it this way, but you never know when a good deal on a KA tranny might come along. You might want to keep your eyes open. Quote Link to comment
Lozer Posted February 23, 2009 Author Report Share Posted February 23, 2009 Thanks thats exactly the info i was hunting for. i woul love to buy a whole parts car for the swap but in reallity im gonna end up doin a piece at a time due to cost. Quote Link to comment
ppeters914 Posted February 23, 2009 Report Share Posted February 23, 2009 For the best solution use the KA tranny. It sits properly oriented in the car, is a far superior tranny and was built to handle the KA's power. The drive shaft will need shortening. I know you don't want to do it this way, but you never know when a good deal on a KA tranny might come along. You might want to keep your eyes open. You'll be able to the 5-speed L tranny no problem. Quote Link to comment
bonvo Posted March 9, 2009 Report Share Posted March 9, 2009 the only problem i see with bending the shifter or the wedge idea is oil you would never get the trans full and always be a little on the low side at least when bolting the l trans to the z or ka now bolting the z or ka trans to an l you would have a hard time getting to the drain/ fill plugs and never get all the oil out of it when you do a fush Quote Link to comment
