what Posted February 16, 2009 Report Share Posted February 16, 2009 Hi. Any one know how many gallons a 1979 kingcab gas tank is? Thank you. Quote Link to comment
Mandingo Posted February 16, 2009 Report Share Posted February 16, 2009 I coulld be wrong, but I believe mine is 10 gallons Quote Link to comment
Bleach Posted February 16, 2009 Report Share Posted February 16, 2009 I'm also not sure, but I believe in the 11-12 gallon range is accurate. Quote Link to comment
KELMO Posted February 17, 2009 Report Share Posted February 17, 2009 Regular Cab: 11.0 gallons King Cab: 14.1 gallons Seems size does matter:D Quote Link to comment
OL YELLER Posted February 17, 2009 Report Share Posted February 17, 2009 Believe this will give ya all the info that you need...this is the '73 Standard cab, and I am fairly sure that all standard cab 620 trucks thru '79 had the same gas tank... shows fuel tank capacity at 11.88 galllons Quote Link to comment
Bleach Posted February 17, 2009 Report Share Posted February 17, 2009 funny how a kingcab uses the exact same bed size as the standard cab... why enlarge the tank? hmmmm.... the tank goes under the bed. Quote Link to comment
datzenmike Posted February 17, 2009 Report Share Posted February 17, 2009 (edited) funny how a kingcab uses the exact same bed size as the standard cab... why enlarge the tank? hmmmm.... the tank goes under the bed. I think he means long bed. The '78 FSM says 11 7/8 US gal. It fails to mention the long bed. Parts listing for '79 calls up two : Short wheel base and KC.... 17201 B9800 long wheel base................ 17201 B9860 this one has to be bigger. Edited February 17, 2009 by datzenmike Quote Link to comment
what Posted February 17, 2009 Author Report Share Posted February 17, 2009 I knew i could count on you guys. Buy the way i have a 1971 521 with the L16 and it is rated at 96 hp. 2 years later according to that 1973 spec sheet the L16 was rated at 92. They detuned them by 4 hp. Crazyness. Quote Link to comment
BarryA Posted March 4, 2009 Report Share Posted March 4, 2009 Regular Cab: 11.0 gallonsKing Cab: 14.1 gallons Seems size does matter:D the tank on my 79 sure doesn't hold 14 gallons - running on fumes, it takes just over 10 gallons topped up. Quote Link to comment
Phlebmaster Posted March 4, 2009 Report Share Posted March 4, 2009 Mine is has never taken more than 10 gallons from empty. :D I have thought about a fuel cell in the bed just to get more miles per tank. Quote Link to comment
Jersey Posted April 10, 2009 Report Share Posted April 10, 2009 my '79 fsm has the standard cab and kc at 13 1/4 gallons and the long bed at 16 7/8 gallons. Quote Link to comment
