Archie Posted January 13, 2009 Report Share Posted January 13, 2009 Hello all, First, Thx to "DatzenMike" and "Yello620" for their earlier replies to my previous post. After much digging around parts stores again, I ended up back at the dealer again, to find out that my driveshaft is equipped with "spiked/peened" ujoints that are not replaceable.:eek: I have to buy the whole drive shaft:eek::eek: Has anyone got any ideas?? I even called our local "Drive shaft Specialist" store and their answer to peened joints of any make, is a whole new drive shaft with yokes using normal aftermarket ujoints. $400.... There has to be another less expensive way to get my ole Nissan back on the road:( Quote Link to comment
datzenmike Posted January 14, 2009 Report Share Posted January 14, 2009 If this is for the Hardbody measure a 720 drive line and see if it will fit. The rear yoke to the pinion may have to be swapped on but that's got to be cheaper. Try a wrecking yard for a used one. Also the D22 Pathfinder used the same platform so the driveshafts may interchange. Quote Link to comment
]2eDeYe Posted January 14, 2009 Report Share Posted January 14, 2009 X2 Some junkyard ends and a trip the local driveline place to have them welded if you can't find a bolt in. Quote Link to comment
Pacific coast Datsun Posted January 14, 2009 Report Share Posted January 14, 2009 Is this for a 86 1/2 or 87 Hardbody? A friend had a similar issue..had to replace the entire shaft. Couldnt you cut off the bad U joints & weld in a new set then get it balanced? Quote Link to comment
coolioni Posted January 19, 2009 Report Share Posted January 19, 2009 On my truck the drive shaft was making terrible noise, they replaced the u-joints which were in stock at the local parts store for a very inexpensive price. I think they were about $25 bucks or so. Quote Link to comment
