lynchfourtwenty Posted December 19, 2008 Report Share Posted December 19, 2008 i notice i always had a little oil on my valve cover, not much but some sprinkles, an i noticed it smoked a tad.. i went an put this hose and filter deal on it an i notice that smoke comes out of the filter.. an when i rev it more comes.. so whats the deal, valve seals? Quote Link to comment
ggzilla Posted December 19, 2008 Report Share Posted December 19, 2008 That is piston rings :-( Quote Link to comment
lynchfourtwenty Posted December 19, 2008 Author Report Share Posted December 19, 2008 say it aint so!!!!!! lol.. hmm maybe time for a compression test?? Quote Link to comment
datzenmike Posted December 19, 2008 Report Share Posted December 19, 2008 Blow by. Gasses are squeezing past worn compression rings that aren't up to doing their job. A compression test is good but a leak down test is better for showing the % of leakage. Up to 25% loss isn't considered too bad. Sounds bad is all. Quote Link to comment
Llittle_Llama Posted December 19, 2008 Report Share Posted December 19, 2008 do they rent out the tools for that at autozone? i want to check mine just to know where i stand, or is that a better tool to just buy and keep on hand? Quote Link to comment
datzenmike Posted December 19, 2008 Report Share Posted December 19, 2008 You wouldn't use it much, and you would need a compressor to use it if you did have it. The compression tester only reads the peak pressure reached. The leak down test shows how much or how fast it leaks out past rings valves or head gasket. Quote Link to comment
b210in Posted December 19, 2008 Report Share Posted December 19, 2008 time for a rebuild, l20b should be easy and cheap, slap some new rings and bearings, and new gaskets and valve guides and you're good to go. Quote Link to comment
lynchfourtwenty Posted December 19, 2008 Author Report Share Posted December 19, 2008 i will be on the lookout for an extra motor then, one i can rebuild while i drive the living piss out of the one i have now Quote Link to comment
ggzilla Posted December 19, 2008 Report Share Posted December 19, 2008 Do this test: open the driver's door, and stand where you can kinda see the back of the truck or exhaust pipe. Rap on the throttle real fast (rev it to 4000 rpm or so, but immediately let off). Do this three times. * If you see any slightly-bluish smoke coming from the back of the truck, that's another sign the rings are shot. This bluish-white smoke doesn't evaporate it just blows away in the wind. * White smoke that disappates is normal. * Black smoke means carb or ignition problems. Quote Link to comment
lynchfourtwenty Posted December 19, 2008 Author Report Share Posted December 19, 2008 nice, good to know, thanks :) Quote Link to comment
datzenmike Posted December 19, 2008 Report Share Posted December 19, 2008 If everything is normal let sit for half hour and restart. Puff of blue? Valve seals. Or guides,but likely new seals will fix it. The head does not have to come off for this. Quote Link to comment
ggzilla Posted December 19, 2008 Report Share Posted December 19, 2008 When I was in the car buying business, that's how we tested to see if a car engine was good: 1. Pull PCV hose, look for faint smoke 2. Rap throttle, looks for smoke If you cannot see any smoke, the rings are good. The test has never failed. Some engines at 150,000 miles are still good. Most at 100,000 miles are still good. A few at 30,000 already have a problem :-) But even so, marginal valve guides & seals can still cause smoke when first starting the engine. It doesn't test for that. That's something you normally only see after letting the car sit a while, then starting it. EDIT: as datsunmike just said. Yep. Quote Link to comment
lynchfourtwenty Posted December 19, 2008 Author Report Share Posted December 19, 2008 last time i did a compression test (not even a years worth of driving ago) but literally like 2 years ago.. anyways last time i did it i think it was like 160 or so accross all cyls, could it have anything to do with sitting alot lately not bein drivin.. cause when i drove her daily it didnt do any of this.. BUT i do ride her hard.. high rpms alot.. but shes always got oil, always has good oil pressure and never over heats... could my exhaust bein broken only a few inches after the header have anything to do with this?? i mean its like snapped completely an the pipe is hangin lol lol i posted after you but ya she has been sittin awhile.. Quote Link to comment
ggzilla Posted December 19, 2008 Report Share Posted December 19, 2008 High RPMs and full throttle are exactly what wear out rings. Aside from old oil... I once wore out a nice Datsun engine in 12 months with high RPM (6000 rpm) blasts on every shift. That's why a big engine is nice, you don't have to wring its neck to get high performance... On the other hand, a Datsun engine crusing at 4000 or even 4500 rpm will last for years. Quote Link to comment
lynchfourtwenty Posted December 20, 2008 Author Report Share Posted December 20, 2008 yea, im pretty damn mean to her.. lol no biggy i wont kill her completely, and like i said i think im going to keep my eyes peeled for a free or cheap l20 thats it working or close to working condition so i can easily tear it apart an replace some shit, prolly do some rod bearings crank bearings piston rings an what not, my timing chain is like new sorta.. so i will reuse it.. i will also prolly use a ka oil pump, i will also re do the valve seals in my a87 head an the seats an guides, maybe some new valves too if needed .. im not looking to spend much or get any additional power, just something i can rely on an abuse alot Quote Link to comment
datrod Posted December 20, 2008 Report Share Posted December 20, 2008 So I guess my Z car needs a rebuild too. I've had smoke & oil blowing out of her. No one would give me a straight answer. now I think you guy's did it for me. Thanks. Quote Link to comment
lynchfourtwenty Posted December 20, 2008 Author Report Share Posted December 20, 2008 yea, damnit!! lol well i will take it easy on her i guess.. since my car isnt in driving condition right now, i really wish i had a garage to work on my car in.. so i could just swap engines an shit an be good to go.. i got the engine already just no where to work on the car :( i think she has 1 last drive in her so im saving it lol Quote Link to comment
DISLEXICDIME Posted December 20, 2008 Report Share Posted December 20, 2008 your truck needs 20/50 and some ring restore Quote Link to comment
lynchfourtwenty Posted December 20, 2008 Author Report Share Posted December 20, 2008 oh yeah?? it would be cheap, an prolly make it last longer at the least eh Quote Link to comment
DISLEXICDIME Posted December 20, 2008 Report Share Posted December 20, 2008 just make sure you let that shit warm up befor you drive it maybe just go 10/ 40 since it is cold Quote Link to comment
lynchfourtwenty Posted December 20, 2008 Author Report Share Posted December 20, 2008 thats what im runnin now, its so fuckin cold out it takes forever to warm up, even the other day i had been drivin around an shit an the only time the needle move was when i got on it gettin on sr500 other then that it ran at like 150 or 160 or something barely past where the guage starts, even in burgerville drive through it didnt warm up for shit, maybe cause i had the heater on i dont know.. lol but i'll give it a try for sure man Quote Link to comment
yello620 Posted December 20, 2008 Report Share Posted December 20, 2008 thats what im runnin now, its so fuckin cold out it takes forever to warm up, even the other day i had been drivin around an shit an the only time the needle move was when i got on it gettin on sr500 other then that it ran at like 150 or 160 or something barely past where the guage starts, even in burgerville drive through it didnt warm up for shit, maybe cause i had the heater on i dont know.. lol but i'll give it a try for sure man If thats all the warmer the motor is getting, then you have a thermostat problem. This cold weather will still allow the motor to warm up and produce hot water for your heater. Quote Link to comment
lynchfourtwenty Posted December 20, 2008 Author Report Share Posted December 20, 2008 i'll keep an eye on it.. t stats pretty new, an its from napa not costless lol Quote Link to comment
ggzilla Posted December 20, 2008 Report Share Posted December 20, 2008 New thermostats are the least trustworthy ones, I think they don't test production runs well enough. In any case, my Mazda pickup didn't fully warm up on a 20 minute drive in 25 degree weather. Normally it fully warms up in about 3-5 minutes. Quote Link to comment
lynchfourtwenty Posted December 20, 2008 Author Report Share Posted December 20, 2008 honestly i dont think theres a problem with it but i'll check it anyways... with all this snow out i wanna do some fucking cookies.. but my brakes arent trust worthy an i dont feel like bashin my truck up haha Quote Link to comment
