hogie1270 Posted March 25 Report Share Posted March 25 I'm looking for a heavy-duty new clutch for my 1985 720 and was wanting some options Quote Link to comment
Thomas Perkins Posted March 25 Report Share Posted March 25 (edited) Got mine back in 2009 from Napa.Done put 106,000 miles on it.Got it the same time as my Jasper remaufactured engine.Mine is also a 85,4x4.2.4. Edited March 25 by Thomas Perkins Quote Link to comment
datzenmike Posted March 25 Report Share Posted March 25 Well you have the 240mm flywheel and clutch so a 30210-10W00 is the stock pressure plate with a clamping force of 400 kilos or 882 pounds. An '82-'83 280zx turbo and 300zx non turbo V6 is 30210-P9510 and 550Kg or 1,213 pounds. An '84-'85 300zx turbo V6 is 30210-P9600* and 600Kg or 1,323 pounds. * will require the matching release bearing collar 30501-N1600 You can order the equivalent from Exedy or whoever you please. Nissan probably has them. Quote Link to comment
bottomwatcher Posted March 26 Report Share Posted March 26 Your engine won't slip a stock clutch so no reason to put on a heavier clamp force its just harder on your leg. Exedy Japan made clutches are good. Quote Link to comment
ElliotV Posted March 28 Report Share Posted March 28 I don't know if the clutch in mine is original or not(I highly doubt it) but its honestly the best clutch I have ever worked its very linear and has a long engagement Quote Link to comment
