Clutch options
  • Replies 5
Well you have the 240mm flywheel and clutch so a 30210-10W00 is the stock pressure plate with a clamping force of 400 kilos or 882 pounds.
An '82-'83 280zx turbo and 300zx non turbo V6 is 30210-P9510 and 550Kg or 1,213 pounds.
An '84-'85 300zx turbo V6 is 30210-P9600* and 600Kg or 1,323 pounds.
* will require the matching release bearing collar 30501-N1600
You can order the equivalent from Exedy or whoever you please. Nissan probably has them.
