thedat Posted March 15 Report Share Posted March 15 Curious what brand of gl4 gear oil 720 owners recommend Quote Link to comment
]2eDeYe Posted March 15 Report Share Posted March 15 I use Sta-lube, it is the easiest to find. Quote Link to comment
ViciousV15 Posted March 16 Report Share Posted March 16 42 minutes ago, ]2eDeYe said: I use Sta-lube, it is the easiest to find. I wasn't able to find it when I was doing the change on my truck so I ended up using a valvoline 80w-90 hybrid that seems to be holding up okay. Quote Link to comment
IZRL Posted March 16 Report Share Posted March 16 (edited) I second sta-lube 85-90. Cheapest non full synthetic I could find. I had a bad/expensive oil seal leak come up immediately after an engine oil change on a 90s car. Will never use full synthetic anything on older vehicles again. Edited March 16 by IZRL Quote Link to comment
Thomas Perkins Posted March 16 Report Share Posted March 16 I use Redline MT-90. Quote Link to comment
]2eDeYe Posted March 16 Report Share Posted March 16 1 hour ago, ViciousV15 said: I wasn't able to find it when I was doing the change on my truck so I ended up using a valvoline 80w-90 hybrid that seems to be holding up okay. Finding any local is a pain. I order from amazon and keep a couple jugs in stock. Quote Link to comment
datzenmike Posted March 16 Report Share Posted March 16 I find the synthetic shifts smoother when cold. With the same effort used with regular gear oil, the synthetic shifts faster. Where down shifting was an effort and often caused a small gear clash, the synthetic was without a problem. I think all base synthetic transmission oil is made by the same manufacturer and different color and additive packages are added by different brands. 1 Quote Link to comment
Thomas Perkins Posted March 16 Report Share Posted March 16 When was the last time you changed your rear end oil.I had to replace my seal not long ago.Nissan still sells them.I bought a extra one. Quote Link to comment
Stinky Posted March 17 Report Share Posted March 17 I just tried Syncromesh, it is more like 10-30. Honda, and some others specify it. It is for newer trans. Quote Link to comment
datzenmike Posted March 17 Report Share Posted March 17 But works really well in old Datsun transmissions. Quote Link to comment
