Manual transmission gear oil
thedat
  • Replies 9
42 minutes ago, ]2eDeYe said:
I use Sta-lube, it is the easiest to find.
I wasn't able to find it when I was doing the change on my truck so I ended up using a valvoline 80w-90 hybrid that seems to be holding up okay.
I second sta-lube 85-90. Cheapest non full synthetic I could find. I had a bad/expensive oil seal leak come up immediately after an engine oil change on a 90s car. Will never use full synthetic anything on older vehicles again.
Edited by IZRL
Finding any local is a pain. I order from amazon and keep a couple jugs in stock.
I find the synthetic shifts smoother when cold. With the same effort used with regular gear oil, the synthetic shifts faster. Where down shifting was an effort and often caused a small gear clash, the synthetic was without a problem.
I think all base synthetic transmission oil is made by the same manufacturer and different color and additive packages are added by different brands.
