SupDoc Posted March 3 Report Share Posted March 3 I'm getting a small oil leak along the top of the timing cover, where it meets the head, on both sides. I changed the inspection cover gasket in hopes that it was the source of the oil, but no such luck. See pictures below. So, now I'm looking at re-sealing the timing cover, which I'm kicking myself for not doing before the engine was installed. Is it possible to to do this successfully, without removing the oil pan and head? I've read some posts about not using RTV where the head meets the timing cover. Is this a bad idea even with high-temp RTV? Any suggestions would be greatly appreciated. Quote Link to comment
datzenmike Posted March 4 Report Share Posted March 4 Loosen the left front most head bolt and tighten to 60 ft lbs. Then do the matching one on the right. They should all be at 60 ft lbs. Then check the two 10mm bolts that tighten the head to the timing cover are snug. It's not the timing chain cover gasket that's leaking. It's the head gasket that's between the head and the top of the timing cover. Checking the bolt tightness may fix this. 1 Quote Link to comment
banzai510(hainz) Posted March 4 Report Share Posted March 4 I say fuck it and run it otherwise youll have to pull it all over again. I use blue clear RTV in the corners but its not a true gareentee fix even then if your anal about oil leaks.(paint block black is the best way to hide this. Quote Link to comment
Stoffregen Motorsports Posted March 9 Report Share Posted March 9 I always run RTV at the top of the timing cover, and on the bottom of the gasket, in the corner where the block meets the timing cover. Quote Link to comment
