Draven521 Posted November 28, 2023 Report Share Posted November 28, 2023 Finally got my truck to run and noticed this. What the issue and is fixable? Quote Link to comment
mainer311 Posted November 28, 2023 Report Share Posted November 28, 2023 You have a Welch plug that rotted from the inside out. Knock it out, then replace it with a brass one, and refill your coolant. 1 Quote Link to comment
Draven521 Posted November 28, 2023 Author Report Share Posted November 28, 2023 7 minutes ago, mainer311 said: You have a Welch plug that rotted from the inside out. Knock it out, then replace it with a brass one, and refill your coolant. How hard is the replacement? Quote Link to comment
mainer311 Posted November 28, 2023 Report Share Posted November 28, 2023 19 minutes ago, Draven521 said: How hard is the replacement? If you hammer a punch into one side of the old one, it should rotate, and then you can pull it out with pliers. Put a little sealant around the edge of the new one, find a socket that fits on the inside, then hammer it in as straight as possible. That’s the easy side of the engine to get to… 2 Quote Link to comment
Draven521 Posted November 28, 2023 Author Report Share Posted November 28, 2023 2 minutes ago, mainer311 said: If you hammer a punch into one side of the old one, it should rotate, and then you can pull it out with pliers. Put a little sealant around the edge of the new one, find a socket that fits on the inside, then hammer it in as straight as possible. That’s the easy side of the engine to get to… Thank you so much! Quote Link to comment
thisismatt Posted November 29, 2023 Report Share Posted November 29, 2023 Change them all for good measure. Likely the rest are similar. 1 Quote Link to comment
Stoffregen Motorsports Posted November 30, 2023 Report Share Posted November 30, 2023 I always clean out the holes with a wire cup brush on a die grinder, or even a drill. Installing a clean plug in a dirty hole will cause it to leak. Quote Link to comment
mainer311 Posted November 30, 2023 Report Share Posted November 30, 2023 3 hours ago, Stoffregen Motorsports said: Installing a clean plug in a dirty hole will cause it to leak. 😏 1 1 Quote Link to comment
banzai510(hainz) Posted December 1, 2023 Report Share Posted December 1, 2023 I drill a hole and had a sheet metal screw in case it went too far in. key is dont damage the round edge. There is also expandable screw in types Datsun is 40mm find the correct one of these in a pinch https://www.ebay.com/itm/235298022736?var=0&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338590836&toolid=10044&customid=0672c3328e9c1a87ad94a658bb4ed7eb 1 Quote Link to comment
