Bobbert Posted October 27, 2023 Report Share Posted October 27, 2023 So I just got a 87 720 from my grandparents and the main problem I found is the brakes. I have to push the pedal in just for it to barely stop. I was wondering if anyone had swapped out the brake drums for rotors and if it was hard to do Quote Link to comment
Bleach Posted October 27, 2023 Report Share Posted October 27, 2023 do you have disc brakes in front? Quote Link to comment
Bobbert Posted October 27, 2023 Author Report Share Posted October 27, 2023 53 minutes ago, Bleach said: do you have disc brakes in front? Drum brakes all around Quote Link to comment
datzenmike Posted October 27, 2023 Report Share Posted October 27, 2023 All trucks after the '77 620 were front disc brakes. You say it's an '87 720? The 720s stopped in '86.5. An '87 would be a D21 Hardbody. Post a picture as I said, all trucks from '78 on are front disc. The build date is stamped on a tag on the driver's door jam. Post a picture of this '87 Check your brake fluid level. If low or empty you may need to bleed them. Perform a brake booster test.... 1/ step on the brakes several times to exhaust any residual vacuum in the booster. 2/ step on the brakes and hold. 3/ start engine. What should happen is the pedal will drop slightly as intake manifold vacuum builds. Quote Link to comment
Bobbert Posted October 27, 2023 Author Report Share Posted October 27, 2023 4 minutes ago, datzenmike said: All trucks after the '77 620 were front disc brakes. You say it's an '87 720? The 720s stopped in '86.5. An '87 would be a D21 Hardbody. Post a picture as I said, all trucks from '78 on are front disc. The build date is stamped on a tag on the driver's door jam. Post a picture of this '87 Check your brake fluid level. If low or empty you may need to bleed them. Perform a brake booster test.... 1/ step on the brakes several times to exhaust any residual vacuum in the booster. 2/ step on the brakes and hold. 3/ start engine. What should happen is the pedal will drop slightly as intake manifold vacuum builds. Grandparents had told me it was an 87 so I had went with it. Thank you for the information Quote Link to comment
datzenmike Posted October 27, 2023 Report Share Posted October 27, 2023 Well lets find out what you do have. Quote Link to comment
Stoffregen Motorsports Posted October 27, 2023 Report Share Posted October 27, 2023 Probably a '77. People now call every Toyota pickup a Tacoma, but those didn't come out until '95. 1 Quote Link to comment
Stoffregen Motorsports Posted October 27, 2023 Report Share Posted October 27, 2023 Either way, there are disc brake conversions for drum brake trucks. 1 Quote Link to comment
Thomas Perkins Posted October 28, 2023 Report Share Posted October 28, 2023 Post a picture and you will find out what kind of truck you have. Quote Link to comment
datzenmike Posted October 28, 2023 Report Share Posted October 28, 2023 On 10/26/2023 at 8:47 PM, datzenmike said: Well lets find out what you do have. 1 hour ago, Thomas Perkins said: Post a picture and you will find out what kind of truck you have. OK... Does it have round headlights? Then eithere a 620 or a 520/521 Look on the door jam for the build date. Quote Link to comment
Bobbert Posted November 1, 2023 Author Report Share Posted November 1, 2023 On 10/28/2023 at 4:53 PM, Thomas Perkins said: Post a picture and you will find out what kind of truck you have. It’s an 84 720, I got it wrecked. I also don’t know how to post on here Quote Link to comment
Thomas Perkins Posted November 1, 2023 Report Share Posted November 1, 2023 Open a Imgur account and load pics there,then you can send them.here. Quote Link to comment
datzenmike Posted November 2, 2023 Report Share Posted November 2, 2023 On 10/26/2023 at 5:11 PM, Bobbert said: So I just got a 87 720 from my grandparents and the main problem I found is the brakes. I have to push the pedal in just for it to barely stop. I was wondering if anyone had swapped out the brake drums for rotors and if it was hard to do OK the front brakes ARE disc and only the rears are drum. There's no easy conversion to rear disc brakes as the drum brakes are more than adequate. If it isn't stopping it's not the fault of the rear drums. Are the shoes wet from leaking wheel cylinder???? Air in the hydraulics and just needs bleeding. The brake booster may not be working. The self adjusters may not be working. All of these are repairable or replaceable. Quote Link to comment
Bobbert Posted November 2, 2023 Author Report Share Posted November 2, 2023 11 hours ago, datzenmike said: OK the front brakes ARE disc and only the rears are drum. There's no easy conversion to rear disc brakes as the drum brakes are more than adequate. If it isn't stopping it's not the fault of the rear drums. Are the shoes wet from leaking wheel cylinder???? Air in the hydraulics and just needs bleeding. The brake booster may not be working. The self adjusters may not be working. All of these are repairable or replaceable. Okay thank you, another thing was the truck don’t like staying on when it is turned on. Right before it comes off it sounds like a fuel pump turning off. I can’t really figure out what the problem is. Quote Link to comment
Bobbert Posted November 2, 2023 Author Report Share Posted November 2, 2023 13 hours ago, Thomas Perkins said: Open a Imgur account and load pics there,then you can send them.here. Quote Link to comment
Bobbert Posted November 2, 2023 Author Report Share Posted November 2, 2023 That’s what it looks like right now. Quote Link to comment
datzenmike Posted November 2, 2023 Report Share Posted November 2, 2023 1 hour ago, Bobbert said: Okay thank you, another thing was the truck don’t like staying on when it is turned on. Right before it comes off it sounds like a fuel pump turning off. I can’t really figure out what the problem is. Well a vacuum leak for the brake booster mentioned previously might be the cause. Find the larger hose to the booster from the intake. On a warmed up engine, pull hose off the intake and have someone put finger over opening to seal it. Does it idle better now? There is a fuel pump relay that has several inputs to enable the pump to keep pumping. 1/ When you turn the ignition on before starting, does the oil light come on? 2/ When running, what does the battery voltage read? Quote Link to comment
Bobbert Posted November 2, 2023 Author Report Share Posted November 2, 2023 5 hours ago, datzenmike said: Well a vacuum leak for the brake booster mentioned previously might be the cause. Find the larger hose to the booster from the intake. On a warmed up engine, pull hose off the intake and have someone put finger over opening to seal it. Does it idle better now? There is a fuel pump relay that has several inputs to enable the pump to keep pumping. 1/ When you turn the ignition on before starting, does the oil light come on? 2/ When running, what does the battery voltage read? When I got it only the rpm meter, oil gauge, and speedometer actually function. Everything else on the gauge cluster doesn’t function not even the lights. Quote Link to comment
Bobbert Posted November 2, 2023 Author Report Share Posted November 2, 2023 The truck doesn’t really idle right when I turn it on I have to press the gas or it just shuts off immediately. I’m not that good with older cars haha. Quote Link to comment
datzenmike Posted November 2, 2023 Report Share Posted November 2, 2023 Listen near the rear of the carburetor while someone turns the ignition on off on off without actually starting it. Ypou should hear a soft clicking sound. Do you? Quote Link to comment
Bobbert Posted November 2, 2023 Author Report Share Posted November 2, 2023 49 minutes ago, datzenmike said: Listen near the rear of the carburetor while someone turns the ignition on off on off without actually starting it. Ypou should hear a soft clicking sound. Do you? Yes it made a click Quote Link to comment
datzenmike Posted November 2, 2023 Report Share Posted November 2, 2023 Good that's the idle cut solenoid and without it gas can't get to the idle circuit. Try turning up the idle speed screw. Quote Link to comment
Bobbert Posted November 2, 2023 Author Report Share Posted November 2, 2023 24 minutes ago, datzenmike said: Good that's the idle cut solenoid and without it gas can't get to the idle circuit. Try turning up the idle speed screw. Where would that be located? Quote Link to comment
