1001001SOS Posted September 28, 2023 Report Share Posted September 28, 2023 So my truck came with one key, and it's not the door key lol. I think these trucks came with just one key (or one small glovebox key at first, but one key for doors/ignition?). So Im guessing the ignition switch was changed and who knows. Is it best to get locks and a new switch on ebay, or try to use the key code in the glovebox to source a dealer key? I'd rather not take the door locks out, but I am okay doing the ignition (again) and having different keys. TYIA. Quote Link to comment
datzenmike Posted September 28, 2023 Report Share Posted September 28, 2023 Pull the door lock apart and remove the tumblers. Now, you can still lock and unlock it even with a Popsicle stick, but who would know this but you. My 620 ignition was this way. Quote Link to comment
Dguy210 Posted September 28, 2023 Report Share Posted September 28, 2023 3 hours ago, 1001001SOS said: So my truck came with one key, and it's not the door key lol. I think these trucks came with just one key (or one small glovebox key at first, but one key for doors/ignition?). So Im guessing the ignition switch was changed and who knows. Is it best to get locks and a new switch on ebay, or try to use the key code in the glovebox to source a dealer key? I'd rather not take the door locks out, but I am okay doing the ignition (again) and having different keys. TYIA. Most older independent locksmiths can cut a dealer key. Just had one done myself off a door code, like 5 mins and $20. They can also look at the cut code and compare that to the key you have beforehand just to make sure it isn't the same. Quote Link to comment
720_Jeff Posted September 28, 2023 Report Share Posted September 28, 2023 I do have a Curtis Code Book. It has all the codes and bitting. If you don't have a nearby locksmith, or he doesn't have the code book, I could supply the bittings. Quote Link to comment
KELMO Posted September 28, 2023 Report Share Posted September 28, 2023 I have cut many keys using that book way back when. I wish I would have "acquired" one of those books and the key gun (as we called it) for punching out the cutting depths. Quote Link to comment
1001001SOS Posted September 28, 2023 Author Report Share Posted September 28, 2023 Thanks all, I think I will call a few locksmiths and see what they say. I had a lost key cut off a door lock a long time ago, was pretty cool watching the 'smith cut, check, grind, check, cut, file, etc to get it working, but it never worked 100%. Glad to hear the key code might get me there, cheers. Quote Link to comment
KELMO Posted September 29, 2023 Report Share Posted September 29, 2023 One thing to keep in mind is when cutting a key by code with a "key gun", all of the cuts will be new and the cylinder will be 40ish years old and worn. Sometimes we would have to buff the snot out of the key or even dull it up a bit using a concrete curb as a "file". Although, some locksmiths these days have a fancy shmancy key cuttin' machine. They also may be more refined than we were as far as using the curb as a file. 1 Quote Link to comment
720_Jeff Posted September 29, 2023 Report Share Posted September 29, 2023 (edited) On 9/28/2023 at 4:07 AM, KELMO said: I have cut many keys using that book way back when. I wish I would have "acquired" one of those books and the key gun (as we called it) for punching out the cutting depths. Got one of those as well, so key gun, codes and blanks. Oh, yeah got a depth gauge. Fun to have the tools. I noticed the new keys would be a bit rough when using to operate the lock So far, wire wheel fixes most of that. Sharp as can be when freshly cut Edited September 29, 2023 by 720_Jeff Quote Link to comment
