vendance Posted July 23, 2023 Report Share Posted July 23, 2023 I bought a 720 4x4 but the seats are destroyed. I read somewhere that rodeo seats will bolt right in but I was wondering if anyone could confirm that or if any other seats would bolt in. Quote Link to comment
Stinky Posted July 25, 2023 Report Share Posted July 25, 2023 I don't know. I looked at a PU in a junkyard and it hd buckets in it. They looked Honda-ish, bery similar looking to the ones in my CRV. Quote Link to comment
720_Jeff Posted July 25, 2023 Report Share Posted July 25, 2023 I had '99 Rodeo seats in mine. If you're tall, they could be an issue, so I've read. They are a little higher. Most will say, they bolt right in. Mostly accurate. Thread the rear track bolts, then work on the front track bolts. The angle of the front flange doesn't match the 720's, but once you thread the bolt, it will draw it back into the right spot and be pretty good. You will need washers for the front bolts, otherwise they won't have enough material to hold onto on the flange. Quote Link to comment
Madkaw Posted July 27, 2023 Report Share Posted July 27, 2023 There are some seats that are very close that you might have to shim or enlarge a hole. I run 300zx seats . The floor of the 720 falls off to the outside so you have to shim the seat level . Some holes have to be enlarged Quote Link to comment
Thomas Perkins Posted July 27, 2023 Report Share Posted July 27, 2023 Like those seats. Quote Link to comment
