robrizzo Posted July 23, 2023 Report Share Posted July 23, 2023 How does one remove this. Screw/pin?? Quote Link to comment
datzenmike Posted July 23, 2023 Report Share Posted July 23, 2023 Look for a roll pin going through the control lever at right angles to that pin. I think I see something there. I have one shown but not exactly where it goes or even if it goes through that pin. The screwdriver slot may be for turning the pin to line up the hole to hammer the roll pin in. If there is one, use a suitable size drift or blunted nail and tap it out. This is just a guess and I would be very surprised if it is. 2 Quote Link to comment
Stoffregen Motorsports Posted July 23, 2023 Report Share Posted July 23, 2023 Yep, tiny pin that holds it in place. 1 Quote Link to comment
robrizzo Posted July 23, 2023 Author Report Share Posted July 23, 2023 I will try looking I see a pin hole. Not sure what way try tri and I need something that small. Thin and strong. Hope it is the ticket. I’ll keep you posted. Thank you 1 Quote Link to comment
robrizzo Posted July 24, 2023 Author Report Share Posted July 24, 2023 Not working. Trying to tap in that little hole with small steel rod. Quote Link to comment
robrizzo Posted July 24, 2023 Author Report Share Posted July 24, 2023 https://ratsun.net/topic/79687-69-521-transmission/ Pin part number 17 removal?? 16 minutes ago, robrizzo said: Not working. Trying to tap in that little hole with small steel rod. Quote Link to comment
Crashtd420 Posted July 24, 2023 Report Share Posted July 24, 2023 32 minutes ago, robrizzo said: https://ratsun.net/topic/79687-69-521-transmission/ Pin part number 17 removal?? Can I ask why you are trying to remove it? I broke that piece trying to remove one.... Quote Link to comment
robrizzo Posted July 24, 2023 Author Report Share Posted July 24, 2023 I need to put on a hood transmission that is missing one. 1 Quote Link to comment
Crashtd420 Posted July 24, 2023 Report Share Posted July 24, 2023 (edited) 28 minutes ago, robrizzo said: I need to put on a hood transmission that is missing one. Couldn't you swap the entire tail housing.... its removable and could be swapped over..... Edited July 24, 2023 by Crashtd420 Quote Link to comment
Stoffregen Motorsports Posted July 24, 2023 Report Share Posted July 24, 2023 Get yourself a roll pin punch, because it's hardened steel and not going to bend while tapping with a hammer. Next, try some heat from a Mapp gas torch on the surrounding shifter base. Heat it, then squirt it with WD40 and give it a hit. If it doesn't budge, let it cool and try it again. It's likely that the pin is rusted into the larger pin. Quote Link to comment
robrizzo Posted July 24, 2023 Author Report Share Posted July 24, 2023 5 hours ago, Crashtd420 said: Can I ask why you are trying to remove it? I broke that piece trying to remove one.... need to put on a good trans and put in the truck 1 Quote Link to comment
robrizzo Posted July 24, 2023 Author Report Share Posted July 24, 2023 I’ll try heating. 1 Quote Link to comment
robrizzo Posted July 24, 2023 Author Report Share Posted July 24, 2023 Changing whole base a lot of work. 1 Quote Link to comment
Crashtd420 Posted July 24, 2023 Report Share Posted July 24, 2023 Just now, robrizzo said: Changing whole base a lot of work. Not really.... something like 6 or 8 bolts... comes right off.... I dont believe there is anything that falls out when removed.... Might need a gasket or you can use gasket maker... 20 minutes or less and you are done... Quick thing are you after the metal piece that attaches the shifter or the aluminum piece on the transmission? Quote Link to comment
Crashtd420 Posted July 24, 2023 Report Share Posted July 24, 2023 I was just thinking if it's the metal part I believe I have that in my garage.... Someone bought the shifter I had but didn't want that piece.... If I can find it you can have it for the cost of shipping.... ill look when I get home.. If it's the aluminum piece you have to take the housing off anyway because the shift rod goes through it . Quote Link to comment
Crashtd420 Posted July 24, 2023 Report Share Posted July 24, 2023 Found it if you want it.... 1 Quote Link to comment
Crashtd420 Posted July 24, 2023 Report Share Posted July 24, 2023 Wondering about shipping I looked at your profile.... Your in Massachusetts.... I'll drive that piece to you.... I'm in central Mass in leominster.... Where abouts are you? 1 Quote Link to comment
robrizzo Posted July 25, 2023 Author Report Share Posted July 25, 2023 14 hours ago, Crashtd420 said: Wondering about shipping I looked at your profile.... Your in Massachusetts.... I'll drive that piece to you.... I'm in central Mass in leominster.... Where abouts are you? I got it off. I want to add photos for others so they know what to do. I want to share because everyone here has been so great 3 Quote Link to comment
robrizzo Posted July 25, 2023 Author Report Share Posted July 25, 2023 15 hours ago, Crashtd420 said: Found it if you want it.... My friend thank you. I got mine off. And swapped. I don’t know how to add photos to share with everyone Quote Link to comment
Crashtd420 Posted July 25, 2023 Report Share Posted July 25, 2023 24 minutes ago, robrizzo said: My friend thank you. I got mine off. And swapped. I don’t know how to add photos to share with everyone At the bottom of the response box is an option to add files.... If not you need a picture hosting site.... If the picture file is too big you may need to resize.. I cheat sometime and take a screenshot of my picture and I can get a small file size.... 1 1 Quote Link to comment
