Power steering tensioner pulley bearing
Donald Husar
  • Replies 5
If the bearing is removable you should be able to find manufacturer numbers on in....
Also try here.... they have a tensioner pulley available.. I assume it has a bearing installed... not sure if its correct or not for your truck....
https://www.nissanpartsdeal.com/parts-list/1984-nissan-720_pickup/steering/power_steering_pump.html
