SWFL Posted February 18, 2023 Report Share Posted February 18, 2023 What size line fitting wrenches are used on the 620 for both the brakes and clutch? I'm 1000+ miles from my tools. And need to replace the clutch master and slave cylinders. I'll probably be doing some brake work as well. Quote Link to comment
Danalive Posted February 18, 2023 Report Share Posted February 18, 2023 i think theyre all 10mm, i had some cheap line wrenchs but they still rounded everything, some penetrating flud and a pair of these https://www.amazon.co.uk/Irwin-Visegrip-4Lw-Locking-Wrench/dp/B00004SBBE have done me well on all my brake and clutch nuts that havent been touched in 20+ years 1 Quote Link to comment
Stoffregen Motorsports Posted February 18, 2023 Report Share Posted February 18, 2023 A good line wrench will help a lot. If they won't break free, try smacking the line wrench with the handle of another big wrench. The shock of the metal on metal is usually enough to crack it free. If it still won't budge, try heating the nut with a handheld torch. Not too hot, just enough to get some heat into it. And be careful of the stuff around the torch. DOn't want to catch anything on fire. You can use a sheet of aluminum to protect the surrounding things from getting burned. Worst and last case, use a vise grips. This usually ruins the nut, but sometimes you gotta do what you gotta do. 1 Quote Link to comment
SWFL Posted February 18, 2023 Author Report Share Posted February 18, 2023 (edited) I like the old Snap In Half ones with the line on the inside of the hex part. The old made in the USA, non polished, Crapman ones were decent for the money. My go to if I don't have a line wrench, is a large pair of USA made Vise Grips, preferably old worn ones that have the smooth tips. Crank them on the tip as tight as humanly possible, with both hands, and then use your palm or a hammer to strike the Vice Grips to jar the fitting loose. I hate to do hack work and jack up fasteners. Edited February 18, 2023 by SWFL 1 Quote Link to comment
datzenmike Posted February 18, 2023 Report Share Posted February 18, 2023 Ohhh... I don't know about that. I've crushed the hollow nut doing that. OK if replacing the lines. Just tight enough so they don't slip. Quote Link to comment
thisismatt Posted February 18, 2023 Report Share Posted February 18, 2023 1 hour ago, Danalive said: i think theyre all 10mm, i had some cheap line wrenchs but they still rounded everything, some penetrating flud and a pair of these https://www.amazon.co.uk/Irwin-Visegrip-4Lw-Locking-Wrench/dp/B00004SBBE have done me well on all my brake and clutch nuts that havent been touched in 20+ years These ^^^, not regular vice grips. Quote Link to comment
datzenmike Posted February 18, 2023 Report Share Posted February 18, 2023 These are for collecting prarie oysters. Quote Link to comment
