russaroll Posted October 8, 2022 Report Share Posted October 8, 2022 Does anybody have any secret techniques to getting the tail housing back on? I'm trying to button up this trans rebuild and the tail housing is kicking my ass. The FSM says it should be in 5th, but it doesn't really say what to do with the tail housing. I've tried 5th, 4th, N, I'm beat and out of sillycone. angryface.jpg tiredface.jpg You're suggestions will be attempted tomorrow. Right now it's beer:30. Thank you Quote Link to comment
datzenmike Posted October 9, 2022 Report Share Posted October 9, 2022 All gears in the neutral positions. Might help to install the shifter into the striking rod and put the pin in. The other end of the striking rod has a finger sticking down called the striking lever. I think they mean the shift lever should be full over in the 5th gate rotating the striking rod as far clockwise as possible but still in neutral. Until it meshes with the shift rods it will want to flop around so you'll have to hold it. Lower the tail and the striking lever has to slip into the neutral gate. R 2 4 NNN <<<<< here 1 3 5 1 Quote Link to comment
russaroll Posted October 15, 2022 Author Report Share Posted October 15, 2022 Did a couple dry runs to just line it up. Then once I got it on, popped it up enough to get some goop in and, BAM. All done. Shifts like butta. Now I just need to finish the motor and the rest of the car 😕 1 Quote Link to comment
