dat_sun720 Posted October 4, 2022 Report Share Posted October 4, 2022 i recently tried to see what was wrong with my drum brakes on my 81' 720 and the adjuster screw is completely seized up. I've tried soasking it in pb blaster, heating it up with a torch, and banging it with a hammer. Quote Link to comment
datzenmike Posted October 4, 2022 Report Share Posted October 4, 2022 I wouldn't hit with hammer. It's threaded inside like a bolt Remove and grip adjuster wheel in a vice using wood to protect the 'star wheel' and use pipe wrench to turn adjuster body. Use lots of heat and cool suddenly with PB or WD-40 several times to shock it. Then really heat it and try to loosen, back and forth to get it moving. Clean thoroughly and use an anti seize compound on threads and brake grease on sliding surfaces. Driving through deep water is unavoidable but neglect isn't. Shoes and pads should be inspected for wear and drums adjusted, if needed, every 6 months but probably this could be extended to yearly. Quote Link to comment
Stoffregen Motorsports Posted October 4, 2022 Report Share Posted October 4, 2022 Yep, that's all you can do. If it absolutely won't come undone, then get another one. 1 Quote Link to comment
Thomas Perkins Posted October 4, 2022 Report Share Posted October 4, 2022 (edited) Also check the brake cable.Mine seized up and I bought Nissan's last driver side one for 85 king Cab 4x4.The adjuster was good.Nissan don't sell them any more.The cable was 75 bucks.The adjusters were about 35 bucks each.You have a driver and passenger one. I just found these on Ebay and looked up the part number and it says it's for a 80-82 Nissan 720.Do they look like your's.https://www.ebay.com/itm/274465251135 Here is a Nissan site also with the same part number.https://www.nissanpartsdeal.com/parts/nissan-adjuster-assy-rear-brake~41200-32200.html.There is one rating on the part,says it was 1/8 inch too long so he cut that off.Here is another site.https://www.ebay.com/itm/162907278152?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D241788%26meid%3Db547f08a0bde4ba0a836e76fdc3d5bf8%26pid%3D101111%26rk%3D1%26rkt%3D12%26sd%3D274465251135%26itm%3D162907278152%26pmt%3D0%26noa%3D1%26pg%3D2563228%26algv%3DDefaultOrganic&_trksid=p2563228.c101111.m2109#rwid.It's a gamble buying Asian parts.I've had some that worked and some that didn't last long.Just don't buy the windshield tank and pump,mine only lasted a short time. Edited October 4, 2022 by Thomas Perkins Quote Link to comment
Slow Loris Posted October 25, 2022 Report Share Posted October 25, 2022 This worked for me just the other day when I was certain my adjusters were not recoverable but I got them free. I removed adjuster from backing plate and submerged the thing in about a 1/4 in of kroil star side down overnight with a spray on the non-star side too. And then wrenched the hell out of them the next day til I got a tiny bit of movement. After that…you’re home free. It seems hopeless. But it’s true. You will get it. I bet a vice like datzenmike say is real nice. Any just the spray of the oil didn’t do much I really had to soak it. Quote Link to comment
