JumboFett Posted September 28, 2022 Report Share Posted September 28, 2022 Hey y’all, I’m trying to figure out if I need a new fuel pump. Among several other upgrades, I replaced the hitachi with a Weber, and I haven’t started the car since July. I’m finally ready to start it, but it just can’t crank enough to get fuel into the bone dry carb. I pulled a hose in front of the pump, and that side is dry too. Before I started taking stuff apart the pump was working, and I didn’t touch it during my tinkering. Also, before anyone asks, yes, there is plenty of fuel in the tank. And yes, I’ve been using starter fluid. Thoughts? 🤔 Quote Quote Link to comment
thisismatt Posted September 28, 2022 Report Share Posted September 28, 2022 Put suction side of pump directly into a can of gas to make sure it'll suck. If that works, likely sucking air or a clog somewhere between tank and pump. Quote Link to comment
datzenmike Posted September 28, 2022 Report Share Posted September 28, 2022 There will be at least 3 hoses and 6 hose clamps on the suction side. If there is a small leak air will get in and if the truck sits a long enough time the fuel will siphon back into the tank, or mostly. Takes a lot of engine cranking to suck it back up hill, fill the filter and get to the pump. I had one like this. If the car sat it was a huge amount of starter cranking. It was faster to dribble gas down the carburetor. It would fire up briefly on this and when revved up the pump would be able to do it's job. Try that. Once the lines are full it should be ok. Quote Link to comment
RyanC Posted October 11, 2022 Report Share Posted October 11, 2022 I had to siphon mine through to the pump outlet on mine then she was fine. Quote Link to comment
banzai510(hainz) Posted October 11, 2022 Report Share Posted October 11, 2022 pour some gas in carb to get it running then it might suck up some gas Unless its plugged Quote Link to comment
Beer Snob Posted October 13, 2022 Report Share Posted October 13, 2022 Same problem on my project truck. Had a bad gasket seal on my sediment bowl. You won't have one on 620 but suction is damn near impossible with any leaks in the system. Once I sealed up my leak it picked up fuel lickety split. 1 Quote Link to comment
banzai510(hainz) Posted October 13, 2022 Report Share Posted October 13, 2022 11 hours ago, Beer Snob said: Once I sealed up my leak it picked up fuel lickety split. Yes make sure the intake hose side dont have a crack. Otherwise no matter how many pumps you put in it will only suck air, I had a cracked line right at the pump and didnt see it. 1 Quote Link to comment
