DwayneOxford Posted March 21, 2022 Author Report Share Posted March 21, 2022 Back on this leak. Removed blower box, want to remove glove box. Looks to be integral with dash. Gotta remove WHOLE dash to remove it? Quote Link to comment
datzenmike Posted March 21, 2022 Report Share Posted March 21, 2022 It's one piece plastic. The inlet for the fan box is right above it. The outer edge inside the plenum is flared upward to keep rain out. There should be a drain to the outside of the plenum also. If blocked with leaves and pin needles the water will pond there and over flow into the fan box. 1 Quote Link to comment
DwayneOxford Posted March 21, 2022 Author Report Share Posted March 21, 2022 Thanx Mike, bout ready to put a dam in and seal off the R cowl vent. Quote Link to comment
DwayneOxford Posted March 21, 2022 Author Report Share Posted March 21, 2022 https://imgur.com/4NAao3z https://imgur.com/A4OQ94v https://imgur.com/0kbnGDg Under cowl cover looks as good/better, siliconed the baffle screw that's direct over blower inlet. https://imgur.com/pfAc4fT https://imgur.com/bTrozIs From looks of sediment, think rain's going somehow into blower box. Suggestions on caulk tape? Suggestions on cleaning AC coil? Quote Link to comment
datzenmike Posted March 21, 2022 Report Share Posted March 21, 2022 The air supply opening has a curled up lip into the cowl area to keep rain water out, but the right cowl vent must be clear to allow draining. It opens above and behind the tire forward of the top door hinge. Hard to see from the outside as there is a plastic splash guard. 2 Quote Link to comment
Draker Posted March 21, 2022 Report Share Posted March 21, 2022 This is common. Check for debris under the cowl. Second check for rust holes. Back when I had my 720, I had rust holes. I cleaned it up and put some sealer on them. 1 Quote Link to comment
DwayneOxford Posted March 21, 2022 Author Report Share Posted March 21, 2022 1 hour ago, Draker said: This is common. Check for debris under the cowl. Second check for rust holes. Back when I had my 720, I had rust holes. I cleaned it up and put some sealer on them. All clean, no rust under cowl cover. 1 Quote Link to comment
Draker Posted March 21, 2022 Report Share Posted March 21, 2022 36 minutes ago, DwayneOxford said: All clean, no rust under cowl cover. That's great news! 1 Quote Link to comment
DwayneOxford Posted March 22, 2022 Author Report Share Posted March 22, 2022 I'll post pics when rain's over. 2 hours ago, Draker said: That's great news! Quote Link to comment
DwayneOxford Posted March 28, 2022 Author Report Share Posted March 28, 2022 Sprayed water where tarp is off, none came to inside. Gonna let it rain like it is and see what happens. 1 Quote Link to comment
DwayneOxford Posted February 5, 2023 Author Report Share Posted February 5, 2023 On 12/20/2021 at 5:45 PM, DwayneOxford said: '83 720 King Cab with sunroof and AC. Took off cowl grille, all clean. Got 2 gallon oil jug blocked up tight under heater. It seems to catch most of it. Has rusty streaks behind under heater.. Not seeing how to include pic. Finally solved this prob. Was leaking around the deflector?? protrusion that keeps cowl vent water from entering heater intake. Had to rain REALLY hard for it to leak. Was the only place left that it could be so I went around it with a liberal bead of this fine stuff I been using MANY years. Made in next county East. Quote Link to comment
datzenmike Posted February 5, 2023 Report Share Posted February 5, 2023 Clean out the cowl drains on either side. If even partly blocked the water will back up or drain too slowly and can and will tip into the heater duct. There is a small lip of metal around it but it isn't much. 1 Quote Link to comment
DwayneOxford Posted February 5, 2023 Author Report Share Posted February 5, 2023 5 hours ago, datzenmike said: Clean out the cowl drains on either side. If even partly blocked the water will back up or drain too slowly and can and will tip into the heater duct. There is a small lip of metal around it but it isn't much. 1st thing I checked. Was leaking under the snout?? flange. Don't know what if anything factory gaskets it with. Quote Link to comment
datzenmike Posted February 5, 2023 Report Share Posted February 5, 2023 Well an RTV dam around it is best then. There is a foam gasket on the top of the fan assembly that seals it to the underside of the plenum. Quote Link to comment
