Z23T Posted April 17, 2023 Author Report Share Posted April 17, 2023 9 hours ago, RyanC said: Reading through this, I should have done a Z18et instead of the l20b rebuild I did years ago. So is this a Z22 from a 720 bottom end with the Z18 head bolted on? sounds easy enough. Yes, it's a Z22 bottom end with Z22E pistons and a Z18ET head and manifolds. The turbo is a cheap chinese T3/T4 unit and I've been lucky it's lasted as long as it has. I had to install larger injectors from a Ford 2.3L turbo motor to be able to run more than 5 lbs of boost, I'm currently at 15 psi of boost. 9 hours ago, RyanC said: Z series means swapping left and right side engine mounts and off ya go right. I'm not sure, I built engine mounting brackets and I use the stock 510 cushions. 9 hours ago, RyanC said: With a new turbo and ECU the Z18 can sing and extra cubes would be usefull. The extra cubes were very noticeable and the extra torque made it a lot more fun to drive. If you already have a Z18ET with all of the fuel system, manifolds, and electronics, etc., a Z22 bottom end swap is worth the effort. If you have to go out and buy a Z18ET and all the stuff to make it run I wouldn't bother. This is 70's technology and there are so many better engine swaps available. 9 hours ago, RyanC said: Nice colour by the way the 510 looking neat and tidy! Thank you. Quote Link to comment
RyanC Posted April 17, 2023 Report Share Posted April 17, 2023 Thanks for the responses, yep old school tech but still easily enough to be pretty modern with cubic upgrade and efi etc adaptable. Enjoy driving it looks like a weapon. Quote Link to comment
Z23T Posted July 4, 2023 Author Report Share Posted July 4, 2023 Twenty plus years ago when I was painting the car I cut out the core support to make room for a bigger radiator and the intercooler. I cut it way to much and air spills past the intercooler and radiator into the engine compartment. Quote Link to comment
Z23T Posted July 4, 2023 Author Report Share Posted July 4, 2023 I was tired of the fans running all the time to cool off the car so I made these panels to fill in the gaps. It made a big improvement cooling the car when it's moving. It was 87 here today and I drove the car for an hour or so and it stayed nice and cool. I made a couple of templetes, and cut the filler pieces from the kick panel of a metal desk. I utilized the 90 deg. bend in the kick panel, and then made my other bend with a jig and a body hammer. Quote Link to comment
Z23T Posted July 4, 2023 Author Report Share Posted July 4, 2023 Painted up and fitted. 1 Quote Link to comment
Z23T Posted July 4, 2023 Author Report Share Posted July 4, 2023 (edited) My battery wouldn't hold a charge anymore so I decided to replace the conventional lead/acid battery with a Odyssey AGM. I moved the battery to the trunk years ago and used GM battery tray to mount it. The GM tray wouldn't hold the Odyssey so I cleaned it up, made some brackets and fitted them to the GM tray. Edited July 4, 2023 by Z23T Quote Link to comment
Z23T Posted July 4, 2023 Author Report Share Posted July 4, 2023 I made a couple templetes, cut them with an angle grinder and lit myself on fire. Quote Link to comment
Rustbin Posted July 5, 2023 Report Share Posted July 5, 2023 I can relate to setting yourself on fire, "Hey whats that burning smell" and really like to see other people fabricate stuff. I might borrow your idea for the battery mount too. Quote Link to comment
Z23T Posted July 5, 2023 Author Report Share Posted July 5, 2023 11 hours ago, Rustbin said: I can relate to setting yourself on fire, "Hey whats that burning smell" and really like to see other people fabricate stuff. I might borrow your idea for the battery mount too. You can buy a mount for these batteries for pretty cheap, this one is only $30 https://www.nexgenoffroad.com/product-p/996121.htm I built the brackets for mine because the car allready had the GM battery tray mounted to it. Quote Link to comment
