22350 Posted November 14, 2021 Report Share Posted November 14, 2021 So, I was just getting ready to reinstall the front drums and decided to remove the bearing to clean it properly.... Big mistake. the bearing is a NSK 32KB02 It doesn't seem to exist anywhere. Anyone have one kicking around? Hoping to not have to replace the race, because of switching brands. Quote Link to comment
datzenmike Posted November 14, 2021 Report Share Posted November 14, 2021 You should never run a new bearing in an old race. The new bearing will come with matching race. https://www.sp-spareparts.com/en/p/32kb02-koyo Inner Diameter Outer Diameter Width 32mm 65mm 15mm 1 Quote Link to comment
Stoffregen Motorsports Posted November 14, 2021 Report Share Posted November 14, 2021 There is another bearing that works but you need to machine a spacer to put behind it. The 320 bearings have a super thick flanged inner race that is non-existent. Quote Link to comment
Crashtd420 Posted November 15, 2021 Report Share Posted November 15, 2021 (edited) Those bearings are still out there but not to easy to find... Mike klotz makes the spacer stroffgren is talking about, the old thick one gets removed.... http://www.bluehandsinc.com/ It uses the 32kb02-11b bearing.... Edited November 15, 2021 by Crashtd420 1 Quote Link to comment
