D21 sway bar for 81 720?
tiny
  • Replies 7
The 2wd are the same all years but the 4x4 is a totally different part number. The 4x4 LCA is very different from the 2wd but the bar does look the same.
Because its so close to you I would definitely give it a try.
2wd 720 and D21s with 4 cylinder were H-190. What ratio? Probably 3.889  Look on the passenger dise inner fender under the hood hinge for the engine plate.
Bottom line
TRANS/AXLE............. FS5W71B............. HF38
38 is 3889, 41 is 4.11 and so on
