Farmer Joe Posted December 4, 2008 Report Share Posted December 4, 2008 its in an L18 with a A87 head in a 521 at the local yard. i know its electronic, but i wanna know a little more about it. heres a pic... thanks for the help! Quote Link to comment
banzai510(hainz) Posted December 4, 2008 Report Share Posted December 4, 2008 Pacific Coast Datsun on here uses one of those, see where that red/grn wire goes to and get that also. Maybe write the color codes where they hook up to also. PCD uses the GM module to get it working right. I Would NOT pay to much money for for. the previous owner could have mounted the dist mount 180 degs so the vacuum advance points the other way. So the Vac adv dont hit the hose. Quote Link to comment
datsunaholic Posted December 4, 2008 Report Share Posted December 4, 2008 That's the external-ignitor version used through the '78 model year ('76-77 in California, everywhere in '78). Needs either the original remote box to work or an HEI module. Quote Link to comment
Farmer Joe Posted December 4, 2008 Author Report Share Posted December 4, 2008 hmm. so do you think its worth 10bux? if theyll let it go for 10 ill buy it. how hard is it to wire one of these up with the HEI module? oh yeah, if i do get it, get the pedistal right? i remember someone sayin that theyre different between dists. Quote Link to comment
banzai510(hainz) Posted December 4, 2008 Report Share Posted December 4, 2008 (edited) http://www.olddatsuns.com/620tech.htm look under HEI upgrade Put motor on TDC then pull out old dizzy and put the new one in. PS grab the dizzy with the mount that goes to the from cover also as one unit. I myself would rotaye the mount so the vac adv is 180deg in the other direction so it not near the water hose yes 10$ is fine up to 20$ But I have a feeling a JY in Washington would want 40$. Jeff Hino's scrapbin 5$ Edited December 4, 2008 by banzai510(hainz) Quote Link to comment
Cuts metal like mad Posted December 4, 2008 Report Share Posted December 4, 2008 got one of those, mine was free, but Its unknown if it works... :) I like them better than the matchbox version myself, due to the ease of use of an hei module for quick and easy replacement. Quote Link to comment
Pacific coast Datsun Posted December 5, 2008 Report Share Posted December 5, 2008 Yes Hainz your correct. I grabbed my dist. from a 610. Niel heres the writeup w/ pix. Wire in the HEI module is very easy... http://japanesenostalgiccar.com/forum/viewtopic.php?p=29633#29633 Quote Link to comment
Farmer Joe Posted December 5, 2008 Author Report Share Posted December 5, 2008 mkay then! well im pretty sure theyd let it go for 10 bux. and ill just pocket a hei module. hmmm, might haves me some electronic ignition!! Quote Link to comment
Pacific coast Datsun Posted December 5, 2008 Report Share Posted December 5, 2008 Buy the dist BUT get the HEI NEW !! Only cost me $25... http://www.partsamerica.com/productdetail.aspx?MfrCode=NIE&MfrPartNumber=DR400CS&PartType=194&PTSet=A Quote Link to comment
Farmer Joe Posted December 5, 2008 Author Report Share Posted December 5, 2008 (edited) Buy the dist BUT get the HEI NEW !! Only cost me $25...http://www.partsamerica.com/productdetail.aspx?MfrCode=NIE&MfrPartNumber=DR400CS&PartType=194&PTSet=A man if i had the money i would, but im still gonna snag one from the yard. money is really tight. i shouldnt really even be buyin the dist. but i dont know if ill ever come upon another one. Edited December 5, 2008 by Farmer Joe Quote Link to comment
banzai510(hainz) Posted December 5, 2008 Report Share Posted December 5, 2008 Dont this 521 have a module somewhere as it didnt come w/electronic ignition. Maybe the guy wired the stock remote box in the truck already. here the diagram for that. Quote Link to comment
