shawninvancouver Posted June 7, 2021 Report Share Posted June 7, 2021 I have been informed it looks like my dizzy was put in off kilter. not put in properly.. can someone explain to me how this happens.>? should vacuum point to front of car or drivers headlight? does it need to be flipped around? re adjusted? wrong dizzy? mount to engine on wrong? i was also told that this is caused by the oil pump gear haft/rod put in wrong. but how does that change where the dizzy sits?? i have looked in the fsm how the dizzy goes on but it does not show how it goes on the mount to engine. this car has never sparked so something is messed up here. any help would again be great.. they previous owner had all plugs lined up from 6 at fan and 1 at firewall... how can i post photos???? Quote Link to comment
banzai510(hainz) Posted June 7, 2021 Report Share Posted June 7, 2021 fast foward to 11.00 mins in to the vid and Im installing a 4 cyl but should be close to a 6 cylinder. soemtime people put the mount that go on the front cover 180 out thus making the dist vqc advanced in the oppisite direction. put motor at TDC first then see where your spindal is and where the rotor points to when the dist is in the middle position then yo can see if maybe the oil pump drive is off a tooth Quote Link to comment
shawninvancouver Posted June 7, 2021 Author Report Share Posted June 7, 2021 how do you post videos and photos without a link??? Quote Link to comment
shawninvancouver Posted June 7, 2021 Author Report Share Posted June 7, 2021 A. how can you tell when engine is on compression stroke for tdc? b,.what happens if oil pump rod to dizzy is in wrong? c. can the dizzy be put on backwards or wrong from the top when it gets put on..?? what " mount on front cover" are you refering to?? that people sometimes put on backwards??? how can i post a photo??? Quote Link to comment
banzai510(hainz) Posted June 7, 2021 Report Share Posted June 7, 2021 (edited) start with part 1 on the vedio then to anwser all your questions watch this from bbeginning to end a few times. then youll figure it out Edited June 7, 2021 by banzai510(hainz) Quote Link to comment
shawninvancouver Posted June 7, 2021 Author Report Share Posted June 7, 2021 here are my photos... what can you tell me from these??? https://photos.app.goo.gl/WLgGdEbRuWiyUjBQ7 https://photos.app.goo.gl/X5p8MS1Mji8Nh8cC8 Quote Link to comment
datzenmike Posted June 7, 2021 Report Share Posted June 7, 2021 Definitely a remote igniter Electronic Ignition (EI) 1 hour ago, shawninvancouver said: A. how can you tell when engine is on compression stroke for tdc? b,.what happens if oil pump rod to dizzy is in wrong? c. can the dizzy be put on backwards or wrong from the top when it gets put on..?? what " mount on front cover" are you refering to?? that people sometimes put on backwards??? how can i post a photo??? A/ Pull the front spark plug and put finger in the hole. Bum the engine with the starter and compression will push your finger out. You are new on the upward travel of the piston on the compression stroke. Find the timing indicator bolted to the timing cover and turn the crankshaft pulley slowly and there will be a small notch that passes close to the indicator. Stop at 0 (zero) and you are at TDC B/ It can be moved to the correct but lets not get ahead of ourselves. If you have not had the drive spindle out or the engine was running then it will be correct. C/ Absolutely impossible to put in 'backwards'. The end of the distributor is keyed to fit the top of the drive spindle. It won't drop down into place till this lines up. Quote Link to comment
shawninvancouver Posted June 8, 2021 Author Report Share Posted June 8, 2021 so it can not be lined up and put on backwards?? gee/ i have now narrowed the NO spark down to two things... either bad electrinic ignition unit or bad pick up coil.. or maybe a loose wire or bad gap - did not look for those yet.. is it super easy to put on the 208zx matchbox dizzy??? anyone know which wires go from coil to dizzY for that?? why are a few people saying my dizzy looks crooked or like a right shoe on a left foot??? how do i fix that??? Quote Link to comment
datzenmike Posted June 8, 2021 Report Share Posted June 8, 2021 It could be out of time but you would still be getting spark. Solve the spark first. Quote Link to comment
banzai510(hainz) Posted June 8, 2021 Report Share Posted June 8, 2021 (edited) Best to start over and tell us what happen exactly before asking was it installed wrong and why if it was pulled out why. Then we can figure this out. If it has no spark the other stuff irrevelent right now unteill we get spark yes he dist can be put on 180 off if the mount was installed 180 off the rotor will be ppointing in the same disrection but the dist housing will be off 180. Unless you know this I will assume this did not happen. linemotor up to TDC and see where the rotor points too and where the plug wire it points too. Watch vedio AGAIN!!!!!! Edited June 8, 2021 by banzai510(hainz) Quote Link to comment
shawninvancouver Posted June 8, 2021 Author Report Share Posted June 8, 2021 ok.. here is distributor off. should be tdc does this look correct?? https://photos.app.goo.gl/dmBQA5WD3351pQvB6 https://photos.app.goo.gl/nHBaVzrKsasxugb26 https://photos.app.goo.gl/JujWjFKYwGRfyKPV6 https://photos.app.goo.gl/N19E6Aq6JakRVSex7 Quote Link to comment
datzenmike Posted June 8, 2021 Report Share Posted June 8, 2021 There are two TDC positions. Compression stroke (the one you want) and the exhaust stroke. If you are at TDC then you are 180 out OR you are not on the compression stroke but on the exhaust stoke. If you are on compression stroke the distributor is 180 out. Easiest fix is to look where the rotor is pointing and that plug wire on the cap now becomes number one. Move all the other wires around counter clockwise in the firing order. Either way you should have spark. How are you verifying that you don't have spark???? Quote Link to comment
shawninvancouver Posted June 9, 2021 Author Report Share Posted June 9, 2021 here is another photo with possibly tdc smal moon side on left.... i may be out a tooth or two,,, no spark still due to bad pick up or bad electronc unit https://photos.app.goo.gl/wC6y8zJvDoxoQVLv5 Quote Link to comment
datzenmike Posted June 9, 2021 Report Share Posted June 9, 2021 Are you at TDC on the compression stroke or not??????? On 6/7/2021 at 1:29 PM, datzenmike said: Definitely a remote igniter Electronic Ignition (EI) A/ Pull the front spark plug and put finger in the hole. Bum the engine with the starter and compression will push your finger out. You are new on the upward travel of the piston on the compression stroke. Find the timing indicator bolted to the timing cover and turn the crankshaft pulley slowly and there will be a small notch that passes close to the indicator. Stop at 0 (zero) and you are at TDC B/ It can be moved to the correct but lets not get ahead of ourselves. If you have not had the drive spindle out or the engine was running then it will be correct. C/ Absolutely impossible to put in 'backwards'. The end of the distributor is keyed to fit the top of the drive spindle. It won't drop down into place till this lines up. Quote Link to comment
shawninvancouver Posted June 9, 2021 Author Report Share Posted June 9, 2021 if possible can you show me a photo of an engine with valve cover off and show me what tdc looks like there.... the mark on flywheel does not seem to work for me as it may not be compression stroke. in engine is piston one up with valves up or down?? i will take valve cover off tomrrow.. Quote Link to comment
datzenmike Posted June 9, 2021 Report Share Posted June 9, 2021 The very front two cam lobes will be pointing up at 2 and 10 o'clock as viewed from the front if on the compression stroke. Now look at the pulley for a notch. It should be close to the timing scale bolted to the timing cover. It might be a pointer on an L26. Quote Link to comment
banzai510(hainz) Posted June 9, 2021 Report Share Posted June 9, 2021 (edited) Again its in the video on what to look for with valve cover off that spindal looks correct just to let you know. Now!!! just look were the rotor points if at #1 plug its most likely correct . Work on getting SPARK first!!!!!!!!!!! PLUS YOU NEVER TOLD US WHY YOU THINK THE SPINDAL IS OFF IN THE FIRST PLACE.. Did someone work on this you or soembody else. Was this working and then stopped working . Or was working then soembody worked on it then not working good. OTHERWISE WE ARE WASTING TIME Edited June 9, 2021 by banzai510(hainz) Quote Link to comment
shawninvancouver Posted June 9, 2021 Author Report Share Posted June 9, 2021 not sure of the history of the car... last owner could not get it to run.. i could not get spark,. changed coil. - power to coil but not out of coil.. i was told it could be the pickup coil or the rusty crusty electronic ignition unit.. so i pulled that... then i looked at dizzzy - some other guys said oil pump shaft could be in wrong.. - i think the main problem is getting it tdc gettting to see where the rotor points and using that spot as #1 spark... BUT with a dead EIU i still need to get a 28zx matchbox dizzy and hook that up.. is that only 2 wires from coil and thats it???? Quote Link to comment
banzai510(hainz) Posted June 9, 2021 Report Share Posted June 9, 2021 (edited) I thinkk your spindal is most liley fine. as your photos you sent looked correct I think you need to get spark. If you swap the coil and put another CORRECT type in than its not the coil. I rarely see a coil go bad anyways. Most time things go bad when they put the WRONG one in there and pops something else. Im not a 260Z expert be nice to see photos of distributor coil set up ect..... most likely it stopped running and was sold and nothing more was done Edited June 9, 2021 by banzai510(hainz) Quote Link to comment
shawninvancouver Posted June 9, 2021 Author Report Share Posted June 9, 2021 i will post some photos.. in the meantime.. do i need to get the spindle to the 11:25 position?? is that the goal here?? Quote Link to comment
shawninvancouver Posted June 9, 2021 Author Report Share Posted June 9, 2021 here are more pics https://photos.app.goo.gl/FLqhQFobCuFvAjRx5 https://photos.app.goo.gl/EmjVfP9nKnz5E4Xp9 https://photos.app.goo.gl/BVAWsYEZegz37Af47 https://photos.app.goo.gl/a292jqt9ZX32QL7q9 https://photos.app.goo.gl/DL1NNqFr4nP4pp6X9 https://photos.app.goo.gl/HKeydKiaagdE8TAbA engine was not tdc for photos.. dizzy just pointing to random spot.. Quote Link to comment
datzenmike Posted June 9, 2021 Report Share Posted June 9, 2021 Find TDC on the compression stroke as mentioned earlier. Then post a picture of where the rotor is pointing. That will tell you if the distributor is in the correct position. We're wasting time on this as the distributor position will not affect whether there is spark or not. Chase down the spark. Now I asked you, how are you testing for spark????? Turning the engine over and it not starting proves nothing. Quote Link to comment
banzai510(hainz) Posted June 9, 2021 Report Share Posted June 9, 2021 (edited) 8 minutes ago, datzenmike said: how are you testing for spark????? take the center coil wire out fro the distributor cap and place near the chassis and start the car. it should spark to the chassis. PS hopefully you know where the plug wires go and the fire order that ignition module loks kinda beat. clean it up and ground it good then re try to see if you get spark as I said before it looke like you had it at TDC 11/25 11/28 is close enough Edited June 9, 2021 by banzai510(hainz) Quote Link to comment
shawninvancouver Posted June 9, 2021 Author Report Share Posted June 9, 2021 bonzai - on my post 20hours ago with dizzy photos.. where do you see it a 11/25 11/28 - am i crazy... i am thinking its at like 1:35 from top right to bottom left... can you please explain that?? i did test for spark by trying to ground plug from coil.. no luck - i did see spark when key was being turned off.. but there is power going into the ballast resistor.. Quote Link to comment
