banzai510(hainz) Posted June 12, 2021 Report Share Posted June 12, 2021 (edited) man I just fix the ballast if that is the proplem and your done. Its simpler and cheaper why make this harder its only a ballast resisitor if its bad. You never even told us if you checked this out then you going to try soemthing you havent done. with a new dist and we got to do 10 more pages on how to do this. fix the ballast if its BAd IT TAKE 3 MINS TO CHECK IT. AS MIKE SAID TO MAKE THIS NEW DIST WORK CORRECTLY YOU NEED TO GET A NEWER LOW OHM COIL THAT MADE TO RUN ON A STRAIGHT 12/14VOLTS. But to use the orginal coil it needs a ballast resisitor. so Im thinking just get a ballast resisitor and be done and save the other dist for later Edited June 12, 2021 by banzai510(hainz) Quote Link to comment
shawninvancouver Posted June 12, 2021 Author Report Share Posted June 12, 2021 i wanna get rid of the electronic box as well.. here are coil specs... will this coil be ok?? Quote Link to comment
datzenmike Posted June 12, 2021 Report Share Posted June 12, 2021 Primary resistance 7 ohms.... good to go! A stock coil from any '78 and up EI system would be just as good. Quote Link to comment
shawninvancouver Posted June 13, 2021 Author Report Share Posted June 13, 2021 CASE CLOSED!!!!! 280zx matchbox dizzy solved all problems...car starts and runs.. for anyone with a 260z and no spark but power to coil.. get rid of electronic ignition unit, get rid of ballast and get rid of old dizzy.. all problems solved Quote Link to comment
datzenmike Posted June 13, 2021 Report Share Posted June 13, 2021 On 6/9/2021 at 3:59 PM, shawninvancouver said: i just watched a video i did of checking for power at the coil area.. power goes to one side of the balast but does not come out the other side and does not get power to the coil.. is that correct??? On 6/9/2021 at 4:02 PM, shawninvancouver said: here is a video of testing the coil... https://photos.app.goo.gl/VQGjda5XKEhDgmwG6 You showed that there was no power to the coil. Only the ballast needed to be replaced. There was nothing wrong with your old distributor. Quote Link to comment
