Beowulf Posted March 8, 2021 Report Share Posted March 8, 2021 Looked at the wheel topics but seems that thread is not used. So that being said, like some input. Have access to some mid 80’s corvette rims that I like, which are high positive offset. But by the time I use the 6 to 5 lug 2” thick adapters I’m back to almost zero offset. Question being has anyone used a similar set up and and problems with using 8.5 wide rims on the front of their 620? Quote Link to comment
datzenmike Posted March 8, 2021 Report Share Posted March 8, 2021 Don't do it. Even free can be too expensive. Know what will fit and go with them. Mate within your own species. Mixed marriages (Corvette 5 bolt and Nissan 6 bolt) just never work out and the offspring of this union are disliked by all. The 620 didn't have a power steering option. The wider the front tires the more effort needed to turn them. An old trick is to run narrower tires on the front. The eye doesn't notice this so much as the rears look way wider than they really are. There are lots of GM 6 bolt in 15 and 16", Ford, Toyota, Mazda, Trooper, later Nissan trucks and 4 or 5 others are also in 6 bolt and aluminum or chrome. Plus all the after market makers for these. Quote Link to comment
Beowulf Posted March 8, 2021 Author Report Share Posted March 8, 2021 10 minutes ago, datzenmike said: Don't do it. Even free can be too expensive. Know what will fit and go with them. Mate within your own species. Mixed marriages (Corvette 5 bolt and Nissan 6 bolt) just never work out and the offspring of this union are disliked by all. The 620 didn't have a power steering option. The wider the front tires the more effort needed to turn them. An old trick is to run narrower tires on the front. The eye doesn't notice this so much as the rears look way wider than they really are. There are lots of GM 6 bolt in 15 and 16", Ford, Toyota, Mazda, Trooper, later Nissan trucks and 4 or 5 others are also in 6 bolt and aluminum or chrome. Plus all the after market makers for these. Ok, I understand. Now most everything I find in 6 lug are still 8; 8.5 in wide and 15” is this still a problem? Quote Link to comment
datzenmike Posted March 8, 2021 Report Share Posted March 8, 2021 You want the tire diameter to be the same as the stock tire height so a 6.00 X 14 is a 175/70R14 that is 23.65" tall. So no matter what width you select make sure it's within 1/2" of 23.65". 8.5" should fit if your wheel offset is correct. Within reason, you can run a narrower or wider tire on an 8.5" wide rim. You don't want the tire outside the fender (negative offset) or it will come down on it. You don't want the wheel in too far positive offset) or it will rub excessively on turns. Wider tires will rub sooner than narrower ones so choose accordingly and be aware of the offset. Quote Link to comment
Beowulf Posted March 8, 2021 Author Report Share Posted March 8, 2021 Thanks for the help. Going to pass on the corvette rims and keep looking at 6 lug that will fit Quote Link to comment
EDM620 Posted March 9, 2021 Report Share Posted March 9, 2021 1 hour ago, Beowulf said: Thanks for the help. Going to pass on the corvette rims and keep looking at 6 lug that will fit I didn't keep the list I'd make of alternative rims, but if you're open to sizes larger than 16" you have GM & Nissan rims up to 18" that will work with very low profile tires These are 18" Armada rims on my 620, original rim was only 14". Your overall diameter needs to remain close to original. 1 Quote Link to comment
Beowulf Posted March 9, 2021 Author Report Share Posted March 9, 2021 Those are nice but jut not the look I want. Plus I’m on a budget (read cheap) lol Quote Link to comment
hobospyder Posted March 9, 2021 Report Share Posted March 9, 2021 i bought a set of 8 inch 0 offset wheels at one point. but i never had any issues before putting spacers on them because i was rubbing the rear calipers. put spacers on all 4 wheels because i dont like the staggered look Quote Link to comment
