butter fingers Posted February 1, 2021 Report Share Posted February 1, 2021 hey guys , my '86 4x4 needs a clutch . what is the best way to go ? should i buy a kit with a flywheel or machine mine ? thanks, butter fingers 1 Quote Link to comment
butter fingers Posted February 1, 2021 Author Report Share Posted February 1, 2021 does nissan still offer a clutch that will fit my truck ? like from a d21 or pathfinder ? butter fingers 1 Quote Link to comment
datzenmike Posted February 1, 2021 Report Share Posted February 1, 2021 The Z24 engines all used a 240mm pressure plate so yes a D21 KA-E or KA-DE will fit (but so will the 280zx turbo and the 300zx non turbo but you won't need that much). I would also get the matching release collar just in case. I think Exedy has a replacement. If flywheel is gouged by clutch disc rivets have it milled. If flat but shiny block sand it with 180 grit to break the glaze. 1 Quote Link to comment
bottomwatcher Posted February 3, 2021 Report Share Posted February 3, 2021 Buy the exedy flywheel, clutch throwout bearing and collar kit. Everything matches, no chinese crap. If you drive sanly don't worry for the next 150k. Also when doing a clutch replace master and slave cylinder. These are wear parts meant to be replaced when the clutch is. Low on cash do what you need to but if you can and want reliability throw those parts on. 1 Quote Link to comment
datzenmike Posted February 3, 2021 Report Share Posted February 3, 2021 If you can find made in Japan clutch and slave masters. The shit that passes for clutch and slaves today is a waste of time buying. They're junk and they are cheap. ...and no, when the clutch and PP is replaced you do not have to replace the master or slave or the flywheel.... you can, but but it's an unnecessary expense if you get good ones and the cheap ones will fail sooner than if you left the factory ones in. Besides these two parts are easy to get at and change unlike a flywheel. Don't fix what isn't broken. The flywheel may need resurfacing yes. 1 Quote Link to comment
butter fingers Posted February 3, 2021 Author Report Share Posted February 3, 2021 very good info guys , i will probably be buying the clutch locally . i was looking for advice on good clutch parts and what clutch kits to avoid . keep on truckin , butter fingers 1 Quote Link to comment
butter fingers Posted February 5, 2021 Author Report Share Posted February 5, 2021 i am looking at buying a clutch kit from NAPA , any advice ? thanks ! 1 Quote Link to comment
banzai510(hainz) Posted February 5, 2021 Report Share Posted February 5, 2021 (edited) get a EXEDY brand clutch kit for your vehicle you can have a machine shop surface the flywheel for you I know you want us to find the link for you!!!!!!!!!!!!!!! stock http://www.importperformanceparts.net/ they have the stag 1 and 2 also Exedy but I would not think you need that. Edited February 5, 2021 by banzai510(hainz) 1 Quote Link to comment
datzenmike Posted February 5, 2021 Report Share Posted February 5, 2021 It's a 240mm diameter. 1 Quote Link to comment
butter fingers Posted February 6, 2021 Author Report Share Posted February 6, 2021 i am now looking for an exedy clutch kit , the voice of reason . thanks L motor god ! Butter Fingers 1 Quote Link to comment
