Where does this wire go?
five10
  • Replies 3
get a ohm meter and ohm that blue wire to the one side of the fuses till it shorts out  then read the Cover of the fuse box and see what it Matches too!!!!!!
to help you its the AIRCOND wire. youll get 12voltsw when the key is on so don't let it hit the body of the car and short out the batter or pope the fuse
Edited by banzai510(hainz)
They are correct..........that wire was installed in the fusebox at the factory, to make installing the dealer installed/aftermarket AC kits easier!  Funny, I just figured this out a month ago, while selling a USED fusebox!  Wonder if the earlier 1969 fusebox had this wire, cuz the dealer installed AC was rare in the 69's............
