Dirtyowlnumber4 Posted December 7, 2020 Report Share Posted December 7, 2020 Anyone else encountered a really sticky throttle pedal? The cable and throttle body on the carb is moving nice the problem is at the hinge point on the pedal in the car. I can make it a little better for a few minutes by oiling it. 1 Quote Link to comment
Charlie69 Posted December 7, 2020 Report Share Posted December 7, 2020 Clean and lube it. Quote Link to comment
datzenmike Posted December 7, 2020 Report Share Posted December 7, 2020 It's barely a hinge, just a pin through two holes in metal just a few mms thick and a spring. If you are sure it's the pedal then take it out and clean it while looking for damage. I guess carpet fibers or underlay and/or dirt from shoes could get in there but I don't know. It's almost always the cable... I converted my 710 from linkage to throttle cable because motorcycle carbs but generally the pin and spring will look more or less like this... . 1 Quote Link to comment
NC85ST Posted December 7, 2020 Report Share Posted December 7, 2020 If it’s the cable, you can get a new one from Nissan. 1 Quote Link to comment
