L521 to PL521 engine frame motor mounts
haubstr
I just got given to me a L521 that had the J13 with the frame motor mounts cut off. I want to put an L series motor so is it better to weld on some L motor mounts to the frame or just find a frame from a PL521 and switch everything over? I'm in NORCAL
It doesn't have to be perfect as I already have a 521 with a KA swap I just need an everyday driver/beater.
  • Replies 3
Cut engine mounts from a 521, 620, or 1980 720 and bolt them to the engine set the engine ine the frame bolt up trans and center the engine in the frame and weld the mounts in.  I have used all 3 mounts and the work fine.
Edited by Charlie69
  • Thanks 1
 I have these available now, they do require some fabrication. Cutting, grinding and welding.
They replicate the stock 620 frame side mounts and allow you to bolt up an L20B.
I also offer a trans mount that is bolt in for this swap.
These mounts also work with my KA/SR conversion mounts if you wanted to go that route.
