brake line organizer
butter fingers
  • Replies 8
There are a few varieties of those clips, some with panel mounting nubs and some without. I have not had luck finding them in the aftermarket so whenever I teardown any type of donor vehicle, I scour it for those weird little clips and such.
GM line separators are bulky and not top quality.
Toyota uses high quality and very compact line separators.
Go to a pick-n-pull and grab a handful.
Hard things to find for sure, I needed some for the brake & fuel lines to secure to the frame on my build. Sourced a few through Amayama Trading Co out of Japan for OEM parts. They didn't have enough of what I needed so I ended up fabbing my own. Apparently most plastics can absorb water, so I found some HDMW stuff which was easier to "machine" with.
After drilling out the appropriate size holes, I slotted them to fit over the lines. Not shown is the new metal cap I made for over the new isolators.
  • Like 3
