hansdh Posted June 1, 2020 Report Share Posted June 1, 2020 Hi. I got a blown headgasket and are going to order the parts, what do i need to order beside the headgasket? 1 Quote Link to comment
hansdh Posted June 1, 2020 Author Report Share Posted June 1, 2020 Mabye i should say it is a z22 from 1984 1 Quote Link to comment
datzenmike Posted June 1, 2020 Report Share Posted June 1, 2020 Z22s weren't in the '84s although it could have been swapped earlier. Z22s are not known for blowing their gaskets. So look between the two pair of exhaust pipes, below the #2 and #3 exhaust side spark plugs just where the head meets the block. The engine size is stamped there... Mistakes and assumptions are made and rather than tear into replacing a head gasket I have to ask what makes you think the gasket is blown??? 1 Quote Link to comment
hansdh Posted June 3, 2020 Author Report Share Posted June 3, 2020 It looses coling-fluid after just a few minutes of driving, the exhaust is more white than before, and it is difficult to start when its hot. It would be fantastic if its something else than the head gasket, but i cant think of anything else that gives theese symptoms 1 Quote Link to comment
datzenmike Posted June 3, 2020 Report Share Posted June 3, 2020 Check the engine ID. If Z24 it adds a lot of weight to it being the head gasket. 1 Quote Link to comment
hansdh Posted June 4, 2020 Author Report Share Posted June 4, 2020 I have some troble taking pictures of my engine because it is stranded on the road some distance away from where I live. But i think it is a z22 because i have only spark plugs on one side, contrary to what i have seen on captain720's videos where he has spark plugs on both sides. This also comes up when I enter the chassis number on a web site I can buy parts. is it rare for the z22 to blow the headgasket? 1 Quote Link to comment
datzenmike Posted June 4, 2020 Report Share Posted June 4, 2020 Europe is possibly different. THIS... just looking will tell you what you have as anyone in 35 years could have changed the engine. Our Z22 and Z24 had dual plugs per cylinder but the much earlier Z20 did come with single plugs. Again, Europe may have been different. Look between the two pair of exhaust pipes. It's rare for the Z22 top blow the head gasket, not impossible. 1 Quote Link to comment
hansdh Posted June 6, 2020 Author Report Share Posted June 6, 2020 got my car back home now 1 Quote Link to comment
wayno Posted June 6, 2020 Report Share Posted June 6, 2020 That would be a Z20, we had them in mileage option packages in the 720 in the USA. 1 Quote Link to comment
datzenmike Posted June 6, 2020 Report Share Posted June 6, 2020 4 plug head and mechanical fuel pump. 1 Quote Link to comment
datzenmike Posted June 6, 2020 Report Share Posted June 6, 2020 What do the spark plugs look like. If coolant is getting in, the bad cylinder will have a clean plug. 1 Quote Link to comment
hansdh Posted June 9, 2020 Author Report Share Posted June 9, 2020 i did not understand how i uploaded video so i took a screenshot of it i will check my sparkplugs tomorrow 🤗 1 Quote Link to comment
hansdh Posted June 15, 2020 Author Report Share Posted June 15, 2020 i can see that cylinder 4 is wet 1 Quote Link to comment
datzenmike Posted June 15, 2020 Report Share Posted June 15, 2020 Not just you, I see it too. FIRST.... do not remove the can sprocket until you have restrained the timing chain tensioner from falling out. Once out it's another 4 hours work to put it right. Avoid this at all costs. Get one of these... and avoid this... I suggest removing the head with the intake left on. Take the carburetor off so any sediment doesn't get stirred up. It's awkward so get help lifting it. Then there is zero chance of breaking a manifold bolt or the intake gasket leaking coolant because they are so damn hard to get at to tighten. 1 Quote Link to comment
hansdh Posted June 16, 2020 Author Report Share Posted June 16, 2020 so then i need to buy a z20 headgasket? I think its is so wierd because the vehicle registration service we got her in europe tells me that i has a 2.2L, but it is possible that it have been swaped one time for all i know. Do you recomend a place to buy gasket? 1 Quote Link to comment
datzenmike Posted June 16, 2020 Report Share Posted June 16, 2020 Z20 gasket is fine although a Z22 or Z24 will work also. Chances are you may get a Z24 gasket as a 'one size fits all'. Do you have a tag in the engine compartment something like this... JNS is the manufacturer Asia/Japan/truck The forth digit is the engine displacement. Here it's an N which is the Z24 and Z24i F is Z20 M is Z22 S is 2.2 diesel J is 2.5 diesel H is VG30i The chassis number will have a code that says what engine was installed at the factory.... in North America anyway. 1 Quote Link to comment
hansdh Posted June 16, 2020 Author Report Share Posted June 16, 2020 this is the only one i found in the engine area 1 Quote Link to comment
Draker Posted June 17, 2020 Report Share Posted June 17, 2020 Dang look at that vin! 1 1 Quote Link to comment
datzenmike Posted June 17, 2020 Report Share Posted June 17, 2020 This is a 4x4??? 1 Quote Link to comment
hansdh Posted June 17, 2020 Author Report Share Posted June 17, 2020 yes it is a 4x4. I just ordered a head gasket now. but is it posible that it is leaking some where else, for example from the manifold intake gasket? 1 Quote Link to comment
datzenmike Posted June 17, 2020 Report Share Posted June 17, 2020 Last night I went through all the posts and didn't see any saying you had a 4x4. I got that from the Y on the tag. Also the M designates a Z22 engine installed. The Z20 has been swapped in 1 Quote Link to comment
hansdh Posted June 17, 2020 Author Report Share Posted June 17, 2020 K for King cab? 1 Quote Link to comment
