Jef-fro Posted April 9, 2020 Report Share Posted April 9, 2020 I’m working on upgrading my 521 to ei but it has a dual point dizzy that seems to make things more complicated.what I am wondering is if I by a hot spark ei dizzy for a l-16 if it will work? Everyone tells me to find a matchbox but as far as I call tell their hard to find Quote Link to comment
Jesse C. Posted April 9, 2020 Report Share Posted April 9, 2020 Check this out https://www.hot-spark.com/1-HS-HIT4-Distributor.htm 1 Quote Link to comment
datzenmike Posted April 9, 2020 Report Share Posted April 9, 2020 Any single points L series distributor will work. I don't see what you couldn't take the dual points distributor shaft out and have it turned down on a lathe. Then get a Pertronix for it. Only down side to either is this just gets rid of the points, period. The Nissan EI matchbox and matching coil also ups the output voltage for hotter sparks 1 Quote Link to comment
Jef-fro Posted April 9, 2020 Author Report Share Posted April 9, 2020 Yeah I think all you 🐀☀️guys have bought all the match box dizzys up😁 Quote Link to comment
Jef-fro Posted April 9, 2020 Author Report Share Posted April 9, 2020 I took a look at the hot spark distributor and it says replaces distributor in some l-16 engines single point versions only maybe I’m reading it wrong Quote Link to comment
Jef-fro Posted April 9, 2020 Author Report Share Posted April 9, 2020 But I do get what your saying I could have that lip turned down on a lathe Quote Link to comment
datzenmike Posted April 9, 2020 Report Share Posted April 9, 2020 I have no faith in the quality of a $100 POS from China. You would be better off spending the money on your known good distributor. Hang on you said your truck is a '69 so it would be a J13 engine. All 520/521 engines were single point. Did I miss something? Quote Link to comment
Jef-fro Posted April 9, 2020 Author Report Share Posted April 9, 2020 I don’t know if the engine been replaced at some point but it’s unlikely because the truck had a 1978 tag on it when I got it🤔 Quote Link to comment
Jef-fro Posted April 9, 2020 Author Report Share Posted April 9, 2020 It not the distributor with 8 wires but it has dual points but only one condenser Quote Link to comment
datzenmike Posted April 9, 2020 Report Share Posted April 9, 2020 Better post a picture of it because I don't think it's a '69 engine, somethings whack. Is the distributor on the driver's side? Quote Link to comment
Jef-fro Posted April 9, 2020 Author Report Share Posted April 9, 2020 Yes and I have not figured out how to post pics on here yet Quote Link to comment
datzenmike Posted April 9, 2020 Report Share Posted April 9, 2020 Select a free picture hosting site such as, but not limited, to...imgur. Take and store your pictures there. When needed go back copy the picture information, come here and paste into your post. Only thing I ask is to NEVER EVER use Photobucket the bane of the internet. Quote Link to comment
banzai510(hainz) Posted April 9, 2020 Report Share Posted April 9, 2020 (edited) A 521 has dual points it’s a L16 In there main set of points will have a bigger condenser I think it’s blk red wire near the valve cover side. one person has used the hot spark and worked but he knew how to adjust the distributor spindal and modify the timmimg plate adjustment correctly so it’s timed correctly.key is the pedestal mount and the plate that comes with the new dist might be more for a L20.I don’t know also one use the stock coil and the ballast resistor.seen Hotspark for like 60$ on Amazon Try it out and let us know. i have to many spare Pertronix and spare single point dists so I have a lifetime of spares. Edited April 9, 2020 by banzai510(hainz) 1 Quote Link to comment
Jef-fro Posted April 10, 2020 Author Report Share Posted April 10, 2020 Yeah you’re right I pulled the distributor earlier and it had two condensers one was hiding and one was larger than the other.when I pulled the distributor I was expecting it to have a gear on the bottom Quote Link to comment
Jef-fro Posted April 10, 2020 Author Report Share Posted April 10, 2020 If I go with the hot spark dizzy and coil do I still need a external ballast resistor ? Quote Link to comment
